  #13   Ban this user!
Old 11-21-2008, 01:35 AM
rightgard is on a distinguished road
Richard
Originally Posted by Hernthehunter View Post
I use Bobcad to do my programming for the parts I run it has the ability to program in the Heidenhain conversational and I use Heidenhains TNC server progran to transfer files to the machine
I am in the process of setting up the same system as you, I have encountered a small problem in that when i post a program that has multisteps, between each step in the code it writes a spindle speed on its own, eg S2000. the controller does not like this,,, If I modify program and take this line out then it loads and runs,,, I am not to sure iof my problem lis with the MP parameters as I dont have a manual with these in,,, Your comments would be welcom and if you have a list of your MP parameters??
  #14   Ban this user!
Old 11-21-2008, 05:44 AM
gus gus is offline
gus is on a distinguished road
It is your post, not the control
  #15   Ban this user!
Old 11-21-2008, 02:45 PM
robinhood2b is on a distinguished road
software
Hi i too run and interact 1 mk 2 with a tnc2500 controller and i use tnc remo software down loaded from the heidenhain website and have done so for years. i create my programmes using ezcam currently running version 16 producing mould tools and it does everything i have asked it to do with out any problems.
Old 11-21-2008, 05:28 PM
Moderator
machintek is on a distinguished road
Remember that EZCAM and FEATURE CAM were married to Bridgeport thus their post processors for the Heidenhain controls worked very well. Anything else was the 'competition" and was not supported.
George
Bridgeport Serier II Interact 4 (Heidenhain TNC 2500) elhosseiny Bridgeport and Hardinge Mills 2 08-10-2011 10:54 PM
Bridgeport Interact - Heidenhain TNC 2500 nycooh General CNC (Mill and Lathe) Control Software (NC) 3 06-08-2011 03:01 PM
Bridgeport Interact 1 - Heidenhain 2500 nycooh CNC Machining Centers 2 07-26-2009 04:40 PM
Bridgeport Interact 1 - Heidenhain 2500 nycooh General Metal Working Machines 0 06-25-2007 03:59 AM
Bridgeport Interact 1 - Heidenhain 2500 nycooh CNCzone Club House 0 06-25-2007 03:56 AM
