| What was this Bridgeport called? Anyone know what this Bridgeport was called with this kind of head set-up? It has a J2 2 H.P. head with a 30 taper spindle. The ram is about 12" wide. Had an extension added. We brought it down from a shop we bought out and used it once for a special job and seemed to work well. What would something like this be worth? We need to get rid of it to make some room. Thanks. |
| well, looks like a series 2 nc base, with a 'T ram' and probably an aftermarket riser, probably semi custom, but not sure |
| Do I not recall that these were supplied with multiple heads and called a hydratrace or some such. Used to make several of an item it once from a master.
__________________ Andrew Mawson East Sussex, UK |
| Hi gtrjunkie Gus is right as somebody has put that T Ram and Head from another Machine onto the series2 CNC The T Ram was used for the Hydratrace Machines which was not cnc the series 2 was a 3axes cnc the head was the third axes, the head on yours is a manual head so it is only 2 axes unless the Knee has been converted to the third axes I think it would be called a Bridgport Series2 Bitsa (a bit of this and a bit of that)
__________________ Mactec54 |
| Thanks for the replys. The T-ram does say Series II on it though. The knee is CNC also. The head has An automatic drawbar and brake control. |
| BPT Frankenstine serisII Where are you, does the cnc control work and what do you think you need out of it? Thank's Kevin |
Kevin, Yes the CNC control works. I am in the Pittsburgh area. Price would be about $4000. |
| Called syil america | BZER1 | Syil Products | 1 | 05-09-2007 03:21 PM |
| What is this called and where can I order it? | Alex_Cole | Benchtop Machines | 2 | 01-23-2007 06:46 AM |
| What are they called | Rhodan | CNCzone Club House | 5 | 08-23-2006 01:29 AM |
| Blind Teeth or so they are called | pinguS | General Metalwork Discussion | 1 | 08-02-2006 03:56 PM |
| What is the white plastic called? | WarrenW | Mechanical Calculations/Engineering Design | 22 | 12-24-2005 09:39 AM |
