Hi. I'm having some problems with a Heidenhain TNC 145 c... The batteries went off and there was no power also on the machine, so the parameters erased form memory. I replaced the batteries and tried to RE-enter the parameters, following the instructions in the Manual, but when i turn on the machine, after pressing CE, it sais "pass over z- reference mark, pass over y- reference mark, pass over x- reference mark" and nothing moves at all. Could this problem occur because of some wrong parameters? Anyone can help? Thanks. |
| Hi, I am Shahid. Obviously there are certain parameters which can hold the machine movements. Simply the 42 no param. can hold the machine if its setting is out.It is related to the potentiometer. There are three options for 0, 1, 2. Check all these settings. If it works OK, otherwise let me infrom i will produce you the orignal parameters. My emila is seeco_pak@yahoo.com |
| Well, this is the first time i try to work on a machine like this. I also learnt a little bit of Hurco programing, but that seems much easier than Heidenhain I know how to turn on the machine, from the main switch, then i press the CE button so that the "Power Interrupted" message disappear.After that, the message "pass over z- reference mark, pass over y- reference mark, pass over x- reference mark" appears and when i press the GREEN button (start button) and Cycle Start button, the Z axis moves a few millimetres and stops(but the other axes don't move at all). It appears that the Z axis moves randomelly, because sometimes it moves downwards and sometimes it moves upwards(after following the same sequence mentioned above). I tried moving the axes by the handwheel, after pressing the "electronic handwheel" button, but it doesn't work (with parameter 52 set OFF). I really think that the parameters are set wrong... |
| You need to get a manual If the Z is at the top of travel, then it is not moving randomly. It will move up until it hits the trip dog, then down to look for th ereference mark. Continue to hit cycle start repeatedly and the other axis will try to home. |
| Ok...but after all axes "go home", how do i get rid of the message "pass over z- reference mark, pass over y- reference mark, pass over x- reference mark". I have a manual but some things are hard to understand if you never worked on such machines. When i try to change from "manual mode" to any other modes, nothing happens. The little red light near the NEW selected mode turns on, but the screen remains the same...with the same message about the reference mark... |
| if it still says that, you are not homed power on "CE" Power enable feed rate override at ~100 percent cycle start [wait] cycle start[wait] cycle start[wait cycle start[wait] cycle start[wait] cycle start[wait] As each axis is homed, with a max of 2 moves per axis, that line should disappear until it is homed, it will do nothing else |
| Aha! It seems to work now I followed the sequence you told me, and the axes home, but after the axes are homed, they still move a little bit, even though the little yellow light ( the "Indicator lamp") is OFF. Now i'm trying to learn how to enter a program into the machine. I'm thinking to sell the machine and that's why i try to turn it on and run a program on it so that the customer can see it works. I'll read through the manual and see how to program it and if i have other questions, i'll ask for your help Thanks. |
#12
| Bridgeport Series 2 Interact 2 Heidenhain TNC 155 | rrossey | Bridgeport and Hardinge Mills | 9 | 05-16-2011 09:29 AM |
| Bridgeport Series 2 Interact 2 Transformer | rrossey | Bridgeport and Hardinge Mills | 27 | 01-23-2007 08:09 AM |
| Bridgeport Interact Series II Power Drawbar | UKRobotics | Bridgeport and Hardinge Mills | 9 | 09-15-2006 08:27 PM |
| Bridgeport Series II Interact 4 & Heidenhein Problems | UKRobotics | Bridgeport and Hardinge Mills | 10 | 04-03-2006 03:27 AM |
| Bridgeport series 1 Interact schematics | Mike Conboy | Bridgeport and Hardinge Mills | 13 | 03-13-2006 10:32 AM |
