I just recently bought a Series I with a Centriod control system on it. I want to upgrade the motor and ad a VFD to it in order to be able to use single phase power and have programmable spindle speed. Does anyone sell a "kit" for a series one that is a pretty straight foward install? Does the motor need to be changed? Does the motor just need a pulley that matches the spindle pulley in order to get the 1:1 and let the VFD take over? |
| You can do pretty much everything you are looking to do by the simple addition of a VFD. No need to change the motor. Check www.driveswarehouse.com. There are many other places - maybe others will chime in and help locate some killer deals on VFDs. ****edit***** I just realized that you are likely asking for details of how to integrate into the original machine control system. I can't help you there. Sorry. Scott
__________________ Consistency is a good thing....unless you're consistently an idiot. |
| If it already has a 3 phase motor, see what the name plate rpm is, if it is ~1700 then it is a 4 pole motor and can usually be run up to 120hz effectively doubling the rpm. If ~ 3500 then it is a 2 pole motor and normally not recommended to go over this unless a vector rated motor is fitted. For the control, ideally you will need analogue spindle output from the controller the level of which is controlled by the S value, this also means you must have a way, either in the controller (parameter) or VFD for scaling this signal to correspond with the S value. Al.l
__________________ “Logic will get you from A to B. Imagination will take you everywhere.” Albert E. (Note: The opinions expressed in this post are my own and are not necessarily those of CNCzone and its management) |
| Al - Are there concerns of overheating? Sorry for the minor hijack but this seems relevant to the thread.... Scott
| You mean at low rpm? Possibly, but You would have to run at prolonged low speed at high current I would think. The knee mills I have that I converted I use in this manner, although they are fortunately fitted with a two speed gear box, I removed the Vari-drive belt in favour of 1:1, For the low speeds, I use the 6:1 gear ratio. Al.
The controller supposedly already has the correct outputs inplace to work with a VFD. As for setting it up, I am not totally sure how that will work. It would be nice to not have to get a phase converter or the likes.
How hard of a job is installing the VFD and getting it setup? |
| You wire two phase in - three phase out to the motor, 2 wire ±10v Analogue from controller to the VFD, Ideally you also need two output signals from the VFD for Zero speed and Up-to-speed to the controller. Some rudimentary electrical/electronics knowledge is a help. For tuning the VFD, it helps if you get one with the self tuning option. I have not done one on a bridgeport, the ones I have are Excello, but the principle is the same. Al.
#10
| Some manufacturers will suggest a de-rating factor, I have used the Mitsubishi 1.5kw for 2hp motors for some time and not had a problem, the VFD also controls the accel/decel so the the inrush is different than starting a motor across the line, the VFD parameters limit things like maximum current etc, DC braking etc. Al.
#11
| Thanks Al! I am stuck on wheter or not I need to get the VFD now or get a 3 phase rotory converter - if I do the later, I can get a "bigger" converter and use it for my lathe if it's a 3 phase. If I don't get a rotory phase converter now, I'll have to limit my lathe search to 220V single phase, or heaven forbid 110V. |
#12
| turbostang, You might want to consider a VFD over a rotory phase converter. Reason is most VFD's can run off single phase. The plus is what ever 3ph motor you want to control will also have variable speed. That way you won't need to change belts or gears as often when serching for that perfect cutting speed. Trevor |
| Mach3 tuning (cuts small stuff fine, but is off on big stuff) | jdbaker | Mach Software (ArtSoft software) | 4 | 03-15-2007 12:30 PM |
| Spindle upgrade | nagjames | Syil Products | 1 | 01-27-2007 02:00 AM |
| X2 spindle bearing upgrade | cncuser1 | Benchtop Machines | 9 | 01-04-2007 07:22 PM |
| Upgrade Motor for a Sieg X3 | CNCadmin | General Electronics Discussion | 13 | 06-21-2005 08:14 PM |
| welding thick stuff to thin stuff - need advice | cross6 | Welding, Brazing, Soldering, Sealing | 5 | 01-13-2005 02:39 AM |
