  #73   Ban this user!
Old 03-19-2008, 09:15 PM
robhrzic is on a distinguished road
bemfarmer, yes, I am aware that the Mach 3 user's guide has a a "Tuning motors" (Section 5.5) chapter, where it shows you how you calculate steps per unit, steps per revolution, acceleration and deceleration curves, etc.... That's not what I am talking about.
I want to know how to go about critical damping / tuning the servo motors to the Gecko G320 drives, using an oscilloscope, as shown on pages 2-3 in the G320 manual:
http://www.geckodrive.com/product.cfm?pid=13
I have never used an oscilloscope before, and would like some sort of guidance / direction as to how to procede in doing this correctly, and most of all safely, without making any expensive "smoke".
I know exactly what you mean about not understanding!
  #74   Ban this user!
Old 03-22-2008, 01:59 PM
I finished installing the sub-panel into the enclosure. I found a "hammer finish" green Rustoleum spray paint that seems to come close to the green on the mill, so I painted the enclosure. Now I am finally ready for Phase II of the wiring, and hooking up all of the connectors for the inputs and outputs.
I also got a chance to finish up the drive design for the Y-axis. I should have all of the stock already, so all I need to do is start making some chips.
ID:	56101   Click image for larger version
ID:	56102   Click image for larger version
ID:	56103   Click image for larger version
ID:	56105   Click image for larger version
  #75   Ban this user!
Old 03-31-2008, 05:26 PM
I finished wiring up the machine control enclosure today. I took the covers off of the G320's and soldered a lead to the test point and ground point, which I'll connect to a common terminal strip for easy access for tuning the drives / motors with an oscilliscope. I wish that the G320's would come with an externally accessible test and ground point, as I REALLY, REALLY, REALLY, did not like soldering anything to the PCB inside the G320 enclosure. I hope I didn't fry anything internally doing this. The "test" access hole is totally useless in my opinion, and I do not see how you are supposed to access the test and ground point through this little opening, that doesn't seem to be anywhere near where it should be.
The connectors and sockets were a lot easier to (solder) use than I thought they would be, and they give the appearance of a really nice looking professional install. The only (male) socket that I've done so far is for the E-stop mushroom. I still need to install the sockets on all of the other input/output wiring.
I am a little concerned, as when I powered it up (not connected to a PC) for the first time, only two of the green LED's lit up on the status board connected to the combo break out board. I also noticed that as I turn the power on and off, I would get some of the other LED'd to light up, but could never get to see all four come on. Why this is, I do not know. On my previous power on test (with only the power and step, dir, and common connected to the G320's) all 4 green LED's lit up.
I hooked up a motor and respective encoder to a one of the connections to see what, if anything happens. To my bewilderment, the motor seems to turn and accelerate, then stall (fault light comes on the G320), repeatedly over and over. I guess the good thing is that it does do something, but i need to figure out why it's operating as it is, and how to adlust whatever needs to be adjusted.
There is a lot of wire and connections here!! I triple and quadruple checked all the connections before I powered it up. I hope that all of the connections are right, and all I need to do now is tweaking and tuning. I hope that I did not damage anything when wiring it up. At least I haven't seen any expensive smoke, yet.
I am really confused about the ERR/RES connection. It seems that if it is not connected to the ENC+ terminal, the G320 remains in a fault state. That's the way that I left it for now(ERR/RES jumpered to ENC+), though I am not sure if this is the right way to connect it, or if I need to do anything else.
I am getting 77 VDC at the power terminals on the G320's, which I believe is right where it should be. Though, I am getting about 7.4 VDC across the ENC-/ENC+ terminals. I thought that this was sUpposed to read 5 VDC. I am not sure why I am getting a higher voltage.
I have yet to receive my proximity sensors, which are backordered. Once I get them, I'll try to see if I can hook up the X axis, and see if I can make anything move under power.
I haven'y connected any of the output relays yet, as I am not sure if I'll be using any, yet. I also made a couple of extra access holes that I installed a couple of large grommets and plugs in, for and future additional connections that may be needed.
I did have to leave one fan out, as I did not leave enough room for it. It interfered with the AC input wiring from the transormer to the power supply prep module. I hope that the 7 fans that are in there will be able to keep everything cool!
ID:	56705   Click image for larger version
ID:	56706   Click image for larger version
ID:	56707   Click image for larger version
ID:	56709   Click image for larger version
ID:	56710   Click image for larger version
ID:	56711   Click image for larger version
ID:	56713   Click image for larger version
ID:	56714   Click image for larger version
ID:	56715   Click image for larger version
ID:	56717   Click image for larger version
ID:	56718   Click image for larger version
ID:	56719   Click image for larger version
  #76   Ban this user!
Old 04-07-2008, 08:07 PM
I switched the "A" phase and "B" phase wires on the G320's, and that solved the accelerating / stalling problem.
I set the gain and damp settings to the default 10 o'clock position, and the limit all the way CW. The servo seemed to be "singing" like it should. So, I figured that it was finally time to install the X-axis drive. I took the left side bearing retainer apart, and placed a .014" shim between the outer races of the angular contact bearings to get rid of the "sponginess" or "springy" feel that I have had in the X-axis since I put the table back together. To my surprise, I noticed that I had installed the AC bearings backwards.
Once I had everything put back together (with the .014" shim), I was pleased that I had no more "springy" feel in the handle. I have yet to actually physically measure the backlash, but I am pretty confident that, at least according to feel, that there is very little, if any.
Once I had everything tightened up, I fired up the controller, PC, and Mach 3 to see if I could make some motion. I tried to jog the X-axis, and I had a brief very slow and jerky movement, and then the G320 would fault. I was a bit disappointed, as I really wanted to see some smooth servo CNC motion. Oh well................
I e-mailed some questions to the support group at Geckodrive, and Marcus very quickly replied, and suggested that I separate the step and direction wires going from the combo board to the G320's, and to use shielded cabling to make this connection. Thanks again Marcus for the quick reply. I see why people say that Geckodrive provides top notch support
I have placed an order for some shielded cabling from McMaster Carr. Once it gets here, I'll re-wire the step / direction wiring and hopefully make some motion.
ID:	57104   Click image for larger version
ID:	57105   Click image for larger version
ID:	57106   Click image for larger version
  #77   Ban this user!
Old 04-10-2008, 08:37 AM
Talking It's Alive!
Finally!!!!!!!!!!!
I re-wired the step and direction wires using (2) separate shielded 22 gauge cables. I am currently able to move the X-axis (using G0 manual input) at about 71-72 ipm. I still have to play with the pulse frequency and accel / velocity settings to get it up to 150-200 ipm rapids, which is my goal.
The only thing that concerns me is that the motor is still a bit "noisy" as it moves the table in the -X direction. When moving in the +X direction it is relatively quiet and smooth. It makes some noise though, and the handles on the table vibrate a little when going in the -X direction. It also seems to get a lot worse at lower feed rates.
When turning the handles manually (with everything turned off, of course) it is very smooth in both directions, no matter how fast or slowly that I try to turn them.
Anybody out there have any ideas as to what may be causing this?
Old 04-10-2008, 09:21 PM
txcowdog's Avatar
Gold Member
txcowdog is on a distinguished road
So the shielded cable did the trick. Nice to see it move, but, for the life of me I don't know why you only get problems in one direction. I wouldn't think it is mechanical since you can not reproduce the problem manually so I have to think electronics and something in the resonance of the driver is causing your problem... but this is really just a guess.
  #79   Ban this user!
Old 05-13-2008, 09:59 PM
FPV_GTp is on a distinguished road
hi
robhrzic excellent work and nice thread write up
cheers
Tags
10 x 54, cnc conversion, grizzly, vertical mill
Grizzly G3102/3 CNC Conversion??? Philip Benchtop Machines 8 02-14-2010 09:40 AM
Alan's Grizzly 9x19 CNC Conversion acondit Mini Lathe 94 11-08-2008 10:21 AM
grizzly vertical mill conversion plans/kits coolman General Metal Working Machines 7 08-09-2007 03:22 PM
Grizzly G3102 conversion questions, servos, steppers, breakouts and more. turbostang General Metal Working Machines 4 05-03-2007 09:19 PM
Grizzly Mill Conversion SPEEDRE Benchtop Machines 1 09-24-2004 07:14 AM
