| Hi Yesterday we had a blackout in the factory and i was worried that it may have affected the parameters of the machine. I shut the machine down completly until i was sure that we had full 3phase power again! When I turned it back on all seemed to be ok and the machine ran without fault for the rest of the day! At the end of the day i shut it down as per usual and then this morning when i started it up all seemed to be fine, it zero returned and has not thrown up any alarms or errors! It was'nt untill I tried to manually tool change to set up nex job that i noticed that Z height had not gone to correct position to execute the tool change! It was aprox 60mm low and the tool holder forks would have smashed into the side of the head had i not noticed it! Now I am pretty sure that it will be a parameter problem somwhere but am not sure how to go about rectifying this problem! Any help would be greatly appreciated! Also i should add the machine has a Heidenhain tnc 2500b controller Last edited by seano_78; 08-09-2007 at 09:14 PM. Reason: forgot to say what controller we use |
| resetting the tool change height procedure (including the parameter)should be in the maintenance manual. I have a classroom book that is at the office that should have this data as well but I have not been there in over a week. Have you tried a cold boot and rehoming it again? George
| 60mm is probabally well out of the axis grid shift parameter, if the tool change position is the zero position of the Z, then it sounds like something shifted on the zero slow down dog for the Z axis. Al.
__________________ “Logic will get you from A to B. Imagination will take you everywhere.” Albert E. (Note: The opinions expressed in this post are my own and are not necessarily those of CNCzone and its management) |
| Attached, I found a tool change sequence showing relevant parameters, and input/outputs. George
| EMC2 Axis Manual Tool Change | tomdoyle | LinuxCNC (formerly EMC2) | 15 | 08-09-2010 09:46 AM |
| Z positioning after changing tool (sequencial engraving) | gravosfera | Engraving Machines | 3 | 05-13-2007 03:25 AM |
| Mysterious Y axis move before tool change | daking | Fadal | 2 | 11-27-2006 12:38 PM |
| Alarm during Tool Change on Bridgeport 320H | ChrisB | Bridgeport and Hardinge Mills | 3 | 08-01-2006 06:07 PM |
| Boss 5 X axis positioning | kewl_cat | Bridgeport and Hardinge Mills | 1 | 01-07-2006 11:04 AM |
