Old 08-09-2007, 04:21 PM
bink is on a distinguished road
Bridgeport PowerPath15 radius ?'s
Hi, I am new at this and looking for some help. I am having a prob getting a
.120 radius looking right. Its close enough, but I would still like to get it right. I am still messing with it, but here is what i have now:
stock dia is 1.75
rapid abs x1.85 z-.120
line abs x1.75z-.120
arc radius abs cw x1.51 z0. r.120 f.007
line abs x-.05 z0.
For starters, is this a correct way of turning the radius? Is it better to cut towards or away from the chuck? Also, if i change my r to .15 , the z to z-.150 and x1.51 to x1.45, the .120 r looks looks fine. I thought that this might be due to the tool nose radius, but it is set correctly (1/32) in the library.
Any help will be much appreciated.
Old 08-11-2007, 12:46 PM
Gncc50 is on a distinguished road
Bad Radius on PowerPath
Check to see if your tool shape is defined correctly and the touch off points are correct. Also check to make sure there is no wear entered in the table.
Old 08-11-2007, 04:25 PM
One of Many is on a distinguished road
Here are some details to this concept. The touchoff point can get a little strange for profiling with center of radius compensation to the radius tool verses actual touchoff points.
DC
Learn cause and effect through experience. Mastering those relationships is the "Common Sense" ability within the art of any trade.
loosing Radius frästkle EdgeCam 4 03-21-2008 12:42 PM
cutting a radius kazam07 General Metalwork Discussion 8 05-25-2007 10:06 PM
Help with radius in mazatrol rstephen Mazak, Mitsubishi, Mazatrol 24 04-05-2007 08:30 AM
Zero Radius Arc Xular Mach Mill 4 12-13-2006 10:10 PM
Circle instead of radius Prboz Mach Mill 7 10-01-2006 10:13 PM
