Old 08-07-2007, 12:17 PM
CASTLEVILLE is on a distinguished road
heidenhain monitor volts
Does anyone know the voltage going to the monitor for a series 1 with heidenhain 151 control?
Old 08-08-2007, 11:35 AM
gus gus is offline
gus is on a distinguished road
I know it is an inverted hercules monochrome signal, and the control runs on 120 volts, but never checked what the operating voltage is
Old 08-08-2007, 12:10 PM
thanks I think that will help me get started with fixing it.
Old 08-08-2007, 12:14 PM
Al_The_Man's Avatar
The majority of older CNC monitors are TTL , also in many cases the horizontal oscillator will not run with out the H. Sync signal present. (blank screen).
Old 08-09-2007, 10:44 AM
gus gus is offline
The manuals on the heidenhain site will tell you the pinout of the monitor, but nothing on monitor guts. If the control is not putting out video, it is the video chip, available pretty cheaply, if that is the case I will go get the number for you
Old 08-09-2007, 06:20 PM
gridley51 is on a distinguished road
I believe the 151 monitor uses about 11 volts dc.Some have an onboard power supply but it sticks in my mind that some get it from a card.
Mark.
Old 10-09-2007, 08:47 PM
bbrreid is on a distinguished road
I have a Beaver mill with 150 control and a blank screen voltage 240 volts at monitor
BR
Old 10-10-2007, 07:39 PM
Brian,here is the link to the 150 maintenance manual.If you look at the flow chart for testing the vdu you will see it has an 11 volt supply.If you have 250 volts at the monitor I can understand why it`s not working.Are you sure the 250 volts is not the supply to the Heid box which has another power supply inside it for reducing the voltages.
http://filebase.heidenhain.de/doku/o...0/gb/sa150.pdf
Mark.
Old 10-11-2007, 06:48 PM
mark, 240v to control and 240v to vdu model 114 I think
sent monitor to omi-monitors.co.uk repair £70 if I need a new tube add £80.
a lot better than £445 for a recon.
Brian
BR
Old 10-11-2007, 06:50 PM
I still have an old BBC monitor that I might try to hook up. a chap from a well known repair company admitted to using BBC monitors in some cnc machine repairs
BR
  #11   Ban this user!
Old 10-11-2007, 06:57 PM
Brian,there`s a psu in the vdu that drops the volts to 11.
I give my monitors to a local tv guy.Last one was £40,one before it was £30.No packing,put it in motor,drive to the shop,get it back two days later.
  #12   Ban this user!
Old 11-09-2007, 04:42 PM
Mark ,next time I will it blanks out I will phone
by the way it was the PSU that needed repair
BR
Need a monitor replacement - Heidenhain TNC 2500 litestat12 Bridgeport and Hardinge Mills 12 05-01-2007 06:03 AM
THC torch volts? turboboy CNC Plasma and Waterjet Machines 9 10-05-2006 07:41 PM
5 volts to 1.5 volts? ZipSnipe General Electronics Discussion 5 08-18-2006 06:18 AM
Boosting three-phase 240 Volts to 480 Volts Old Car Guy Phase Converters and VFD 6 05-01-2006 10:27 AM
24 Volts from Computer PS Jason Marsha General Electronics Discussion 2 01-18-2006 10:19 PM
