Old 08-06-2007, 03:27 PM
bherr is on a distinguished road
3 Phase Current draw???
As many on the CNC forum know I've been having problems with my BP series II Interact 4, were the spindle keeps shutting down during a cycle run. Today I got out my Fluke Amp meter and decided to measure the current draw on the three legs of the phase converter during a cycle run. Here are my readings:
Leg #1 8.1 amps
Leg #2 7.8 amps
Leg #3 3.2 amps
Now I'm no rocket scientists, but it seems to me that the third leg is way to low for current. the voltages are as follows
#1 - #2 ----- 230 volts
#2 - #3 ----- 220 volts
#1 - #3------ 225 volts these are all with the machine running a cutting cycle.
Anyone got any suggestions? or can tell me if these readings are good??
Ben
Old 08-06-2007, 04:06 PM
Al_The_Man's Avatar
You didn't say wether this is a Rotary PC or static.
You may need to improve the power factor by a bit of Cap tuning.
Here is some JPG from the help I got from the Guru, Fitch Williams.
These are for a RPC.
ID:	41798   Click image for larger version
ID:	41799   Click image for larger version
ID:	41800   Click image for larger version
Old 08-06-2007, 04:11 PM
pointcloud's Avatar
Prototyper
pointcloud is on a distinguished road
Check your drives. HOT?
Check the compasitors, are there any leaks?
Also you can reverse the rotation on the phase converter, but you would have to change the drives on the machines too. But this can sometimes be a problem solver..
The veriances can be what you have listed.
Normally rotery phase converters do not give problems after start up has taken place..
Think its a drive...though...
Hey check out my website...www.cravenoriginal.com
Thanks Marc
Old 08-06-2007, 04:16 PM
Al_The_Man's Avatar
BTW when you take a current reading, make sure you do not include any loads that are 1 phase fed from the main two 1phase supply.
IOW make sure the current reading is for 3 phase loads only, otherwise you will get an unbalanced reading.
How to determine actual current draw for a servo bgolash Servo Motors and Drives 8 02-01-2008 02:32 PM
rated current per phase CATCH22 Stepper Motors and Drives 5 05-16-2007 08:17 PM
gecko 210: low current draw? anthony Gecko Drives 2 05-28-2005 03:19 AM
current per phase for power supply? FLUTE HEAD General Electronics Discussion 3 07-31-2004 01:41 PM
3 phase with idler and draw string only gtslabs General Electronics Discussion 2 06-19-2004 05:11 PM
