| All, On my Series II, BOSS 6 machine I lost Z-Axis movement!!! Can some one please help! It was running fine, but in the program I overtraveled the quill. Now I get no movement in jog. I was able to move it off the limits by holding in the limit overide, but now when you hold down jog, the drive motor "twitches" a little, then sounds like its spooling up, but the belt does not turn and obviously the quill does not move up... Any ideas??!! |
| Did you check if the motor shaft was turning? you may have sheared a pin or key on the pulley. Al.
__________________ “Logic will get you from A to B. Imagination will take you everywhere.” Albert E. (Note: The opinions expressed in this post are my own and are not necessarily those of CNCzone and its management) |
| Yeah, no motion on the motor shaft... The drive pulley is still frimly attached... I pulled the belt off the motor to take load off the mottor and still nothing. It "twitches" a bit, then holding the jog + it sounds like the motor is spinning, but its not... |
| Yes but did you drop any of those tiny washers or screws? I cannot tell you how many times I found one of those laying across 2 terminals on that side door. Check carefully the terminal strip at the very bottom and the board with the 12 diodes. George
#10
| Which board have you replaced, the printed circuit board or the aluminium channel with 4 Transistors attached. I think machintek is on about the aluminium channel one but if you've changed that try changing the printed circuit board (SMD) one with one off another axis. Also you could try flipping the ACC printed circuit board and see if the problem moves on to the X axis. Chris |
#11
| Something else to try. Attach a meter to the base of each Z transistor (one at a time) and set it to DCvolts. Put the machine in step and step each transistor at least 4 times. They should turn on and off crisply. If you have a bad diode on that board on the bottom right of the side door, one transistor will be off, turn on half way, turn on fully, turn off half way, You may or may not have this problem. This has happened to me only a few times in 25 years. But it can cuase symtoms such as yours. Another very remote possibility is a flaky optocoupler on the output of the ZDI. I had one machine do this. It sends the commands to the SMD. George
| On the Z-axis, All Movement Above Zero Are Positive - Right? | TheNigerian | Machines running Mach Software | 3 | 05-22-2006 09:46 AM |
| Axis movement is not smooth | bgolash | Stepper Motors and Drives | 6 | 12-19-2005 04:36 AM |
| Arrow key movement issues on Y axis. | chrispy | Mach Software (ArtSoft software) | 8 | 08-25-2005 12:56 PM |
| Axis Movement | UKRobotics | General Metal Working Machines | 2 | 12-17-2004 02:33 PM |
| 4th axis movement (and a few other gen ?s) | corpse | General Metal Working Machines | 2 | 08-04-2004 07:13 PM |
