Old 08-04-2007, 06:53 PM
bherr is on a distinguished road
BP series II Interact 4 tool release problem
Over the past several weeks I've been having problems with my hydraulic/air tool lock. I finally found were it was leaking, but now I can't get the tool release to work. A lot of hydraulic fluid has drained down past the spindle shaft and i think it's become filled with the fluid. when I hit the tool release button I can actually see the hydraulic cylinder brace buckle and the top brace of the ball screws is getting depressed. I'm trying to figure a way to get that hydraulic fluid out of the shaft, but don't have a manual, so afraid to do certain things. I've attached some photos for your review. If anyone out there in CNC land has the drawings of the spindle assembly or knows how to get this hydraulic fluid out, PLEASE let me know.
thank You,
Ben
ID:	41712   Click image for larger version
ID:	41713   Click image for larger version
ID:	41714   Click image for larger version
Old 08-04-2007, 10:03 PM
spock is on a distinguished road
Is the cylinder not coming down far enough to eject the tool? If you have had a leak, you may need to bleed the air out of the system, to allow the pressue to bulid enough to push the cylinder hard enough.
Old 08-05-2007, 07:43 AM
tool release
The hydraulic cylinder has been bleed and is working. My problem is the tool release is activated by the hydraulic cylinder pushing the spindle shaft down to release the BT40 tool holder. This shaft which was working fine before I went on vacation is now binding, I believe due to hydraulic fluid inside the shaft, preventing the shaft from going down all the way to release the tool holder. I can actually see the cylinder brackets being pulled inward from the pressure.
Ben
Bridgeport Interact 412 Tool Changer Problem RMARCH Bridgeport and Hardinge Mills 17 05-09-2011 11:57 AM
BP Interact 412 - Tool Release not working dpsol Bridgeport and Hardinge Mills 4 08-02-2007 10:13 AM
BP Interact 412 - Tool Release not working dpsol Bridgeport and Hardinge Mills 0 06-28-2007 11:32 AM
Bridgeport Series 2 Interact 2 Power hook up problem! Help! Huntersyv Bridgeport and Hardinge Mills 7 01-09-2006 02:57 AM
Tool Release Button, Ken_Shea Haas Mills 3 08-04-2003 09:27 PM
