Old 08-01-2007, 06:02 AM
ant771 is on a distinguished road
BP Series 1 measures of spindle
Hi everybody! I'm new on this forum. Running BP Series 1 with Mach3... So I'm making new lug nut for tooling(I'm going to use DIN2080 ISO30) of my bridgeport. So here some questions. First, what is spindles screw measure?
I have measures: 60.2mm diameter, 16 threads per inch = 1.588mm, 60degrees. Are these right?
http://vectron.homelinux.net/ant771/spindle/Spindle.JPG
And what is 60.2mm in inches? Should find picture how to make that screw with turn. I have screw making tables only for Metric-system...
Here's picture of spindle with lug nut. This machine is not mine, but samekind.
http://mysite.wanadoo-members.co.uk/...s1Ret/CNC3.JPG
Old 08-06-2007, 10:33 AM
Is the nominal diameter 2 and 3/8 inches(60.325mm) ?
Old 10-20-2007, 09:15 AM
Had to make 5 testpieces before this final part!
http://vectron.homelinux.net/ant771/cnc/mutteri2.jpg
http://vectron.homelinux.net/ant771/...eri_kiinni.jpg
Old 10-20-2007, 09:20 AM
Had to make 5 test pieces before this final part..
Now it's possible to use DIN2080 - ISO30 toolholder.
Series 1 Spindle kewl_cat Bridgeport and Hardinge Mills 0 07-17-2007 10:44 AM
problem with BP series 1 spindle not working zoqdi Bridgeport and Hardinge Mills 0 02-06-2007 04:04 PM
Boss 5 series 1 BP, spindle wont start signweld Bridgeport and Hardinge Mills 3 11-16-2006 07:21 PM
Adjusting Spindle Speed on Series I wood_donkey Bridgeport and Hardinge Mills 6 01-09-2006 11:14 PM
BP Series 1 CNC- spindle won't turn on MDA40 Bridgeport and Hardinge Mills 3 11-08-2004 09:05 PM
