I have a J head which I've been using Vactra #2 way oil in for the spindle. After topping off the oiler at night, I end up with a puddle of lube on my vise the next morning. Is this normal or should I be looking into a rebuild ? |
| Mine drips oil to. A little more then I would like to see how ever given that the machine is 25 years old it leaks less then my car probably does..hehe Becides the oil is light and wipes pretty easy. I've learned to leave a rag on the machine and to put put a paper towel screen the first time I spin it up after sitting a day or 2 else I'll get splattered..hehe b. |
| Yup. Normal. Getting nice clean oil out of the spindle is comforting - it lets you know your spindle bearings are clean and happy. It also lets you know that the oil labyrinth 'seal' at the spindle end is sealed as it should be, keeping debris out of the lower spindle bearing. I would recommend using a different oil for the spindle bearings - not way lube, but I can't say for sure that way lube would be bad for the bearings. EDIT*** See this thread: http://www.cnczone.com/cg...2;t=001083;p=0 Scott
__________________ Consistency is a good thing....unless you're consistently an idiot. |
Thanks everyone for your input. I guess I'll need to invest in a shop apron ! BTW, I have a Trak MP10 DRO which I can't figure how to set the absolute origin other than to cycle the power. I was able to set the relative origin. The buttons are X, Y, PRESET, INC/ABS, RSTR, and IN/mm. I've tried a number of different sequences button haven't stumbled on the right ones yet. Its an older unit and Southwestern wasn't even able to help me out. |
| Sweo spindle drive? new mill dead spindle | Shizzlemah | Fadal | 13 | 12-18-2008 12:11 PM |
| interact 4 spindle drive won't turn on spindle | 0041601 | Bridgeport and Hardinge Mills | 7 | 06-23-2008 06:51 PM |
| spindle help | woodguy60 | Commercial CNC Wood Routers | 4 | 03-04-2007 09:13 PM |
| more rpms for spindle motor and spindle | bob1112 | Mechanical Calculations/Engineering Design | 33 | 02-10-2007 02:01 PM |
| Just had my spindle reground by Spindle Grinding Service! | Edster | Fadal | 30 | 06-16-2006 11:48 PM |
