Results 1 to 3 of 3
Thread: EZ-Trak DX strange wiring problem solved
    Jul 2007
    Disclaimer: I got this machine used so wiring changes may have been made so this may not pertain to any or all machines.
    After I unload my new/used machine and quickly wire it up, like a small child I can’t keep my paws off the buttons and knobs. So I turn the Flood/Mist switch and “poof” the machine shuts down like the E button was pushed. Turning to the manual wiring diagrams I locate the fuses and discover both 7 and 8 are blown. After two days of tracing wires and a small pile of blown fuses I discover what I think is the problem. Someone must have replaced the duplex receptacle on the side of the machine. This is the 120v one that says work light and coolant. Notice the two different words. It turns out when the duplex receptacle was replaced the bonding strip between the two receptacles was not cut so when the switch was turned it shorted between the two receptacles. I doubt anyone will run into this but it might be something to file away in the back of the brain if replacing this receptacle or having this brain twister show up sometime.
    Bill
    Last edited by WagonWheel; 07-20-2007 at 05:42 PM. Reason: coolant/mist to flood/mist name change
    Dec 2005
    Don't you just love how sloppy some "technicians" can be????
    Hopefully the idiot who did that didn't take all the wire tag numbers off the wires that BPT put on when they built it. This makes tracing wires much much easier.
    Jul 2007
    The thing I kept thinking about was the machinist that always ran this machine. My goodness he must had to have a CNC arm not to have accidentally turned that switch instead of the spindle switch at times.
  1. Strange G03 problem
    By sploo in forum Mach Mill
    Last Post: 11-14-2006, 06:24 PM
  2. Problem Solved
    By widgitmaster in forum CNCzone Club House
    Last Post: 06-20-2006, 02:14 AM
  3. system Wiring diagram, BMI Trak W/LCD needed
    By bsllc in forum Bridgeport and Hardinge Mills
    Last Post: 02-17-2006, 04:18 PM
  4. Ultimate Tech Problem Solved!
    By shootingarts in forum DIY CNC Router Table Machines
    Last Post: 12-31-2005, 11:58 PM
  5. strange motor problem
    By sp00k1e in forum General Electronics Discussion
    Last Post: 03-23-2004, 06:46 PM
