Old 07-17-2007, 10:44 AM
kewl_cat is on a distinguished road
Series 1 Spindle
I have a Boss 5 Series 1 and last night I had a new problem that I have not run into previously. My spindle kicked off in the middle of a program. It was a little bit of a heavy cut in aluminum. I turned the spindle switch off, hit the limit switch, hit the spindle enable and it restarted. The problem is that the feed did NOT stop!! Could have been bad if I was not able to quickly hit the E-stop. Any ideas why it didn't kick out the relay? I think the CR2??? Thanks in advance!
problem with BP series 1 spindle not working zoqdi Bridgeport and Hardinge Mills 0 02-06-2007 04:04 PM
Boss 5 series 1 BP, spindle wont start signweld Bridgeport and Hardinge Mills 3 11-16-2006 07:21 PM
BP Series 1 spindle speed / all out of whack... New Ajax dos reinstall... peter.blais AjaxCNC Control Products 5 08-07-2006 12:54 AM
Adjusting Spindle Speed on Series I wood_donkey Bridgeport and Hardinge Mills 6 01-09-2006 11:14 PM
BP Series 1 CNC- spindle won't turn on MDA40 Bridgeport and Hardinge Mills 3 11-08-2004 09:05 PM
