Old 07-15-2007, 01:19 PM
dfelice is on a distinguished road
need Bridgeport discovery DX32 programming help
I don't understand why this program won't run.
I always get "parser: bad arc radius or endpoint" on line 45.
N5 G70 G75 G90 G17
N10 G0 X0 Y0 T07 M6
N15 S1783 M3
N20 M8
N25 G0 X2.9380 Y-1.0000
N30 Z.1000
N35 Z-.1000
N40 G1 X3.1880 F8.0
N45 G3 X3.1880 Y-1.0000 R-.2500
this is not actually the end of the program, but the line it always fails on. The tool dia. is set to zero
Any help is appreciated.
Old 07-15-2007, 01:29 PM
Moderator
machintek is on a distinguished road
I am not a programmer but check your programming manual. I do not believe that a radius can be negative.
I am assuming that you are trying to move 360 degrees.
Try a G79. Look it up.
George
Old 07-15-2007, 02:02 PM
thanks, I removed the negative from the radius, and it did not help.
Your right about the G79, it is a circular bore. My problem is this program was posted by Espirit. It has happened to me a few times now, and I want to figure it out so I can either change the post processor or whatever setting in the mill is causing the error.
Old 07-15-2007, 08:56 PM
OK, I realized for a 360° circle it needs to be programmed different. The programming manual states, "to program an arc of 360°, either the x,y, or z endpoint must be programmed together with the arc center". Unfortunately it does not give an example. So, I changed line 45 to read
N45 X2.9380 Y-1.0000 I3.1880 J-1.0000 R.2500
It still didn't work, but rather than error out, it moved from the arc center to the arc endpoint at the programmed feedrate and then rapid traveled back to the arc center.
I then tried
N45 X3.1880 Y-1.0000 I2.9380 J-1.0000 R.2500
This failed immediately.
Now that I know the programming must be different I know I'll need to edit the post processor, but to what. I couldn't seem to make it work using what the programming manual told me and manually entering the commands. I didn't spend to much time on it, it was 8pm on Sunday evening, so I quit for the day.
Anyone have any suggestions?
Old 07-15-2007, 09:09 PM
thanks,
Old 07-15-2007, 11:12 PM
CNCRim's Avatar
I think it's better you should change your post processor so it output I and J, it's better that way. I know some machine won't take radius more than 180deg, therefore you must break circle in two quadrant(N40 G1 X3.1880 F8.0
N45 G3 X3.6880 Y-1.0000 R.2500, X3.1880 Y-1.0000 R.2500). Change you post!!!!!
Old 07-16-2007, 07:05 AM
gdwood3rd is on a distinguished road
Good Resource
For older Hardinge/B'Port Iron, Go to Solverstechline.com. They are former H/B'Port employees with the 411 to help you out.
Old 07-17-2007, 08:19 AM
I tried changing the X,Y to I,J it did not operate correctly. It acted as if it were trying to cut a circle 3.188 inch radius and start at 180° in the circle rather than starting at 0°.
thanks for your suggestions.
Old 07-17-2007, 09:24 AM
Moderator
A long time ago I used EZCAM on a MAC and I would draw a small circle tangent at the top to the large circle. I would create points at the 45 degrees on the smaller circle and at 0 and 180 on the large circle. Thus I would start my cut on the smaller circle at 45 degrees, arc in to the tangent point at 0 degrees, continue on the larger circle to 180 degrees, continue to the 0 degree tangent and continue to the -45 degrees on the smaller circle.
Thus it would arc in, mill my circle and arc out. I would have a minimum dwell mark on my circle and it was the most reliable way of getting the EZCAM to do what I wanted it to do. It did post with I J. I believe most post processors do.
George
Bridgeport DX32 post Chris Rand Post Processor Files 2 11-19-2008 04:27 PM
DX32 questions (Bridgeport Torq Cut 22, DX-32, DX 32) vettespeed Bridgeport and Hardinge Mills 11 02-03-2007 03:14 PM
Bridgeport Discovery 308 jdfelice Bridgeport and Hardinge Mills 0 09-13-2006 06:43 PM
Bridgeport Discovery 308 W/SX-15 Control Start up disk needed Richardd Bridgeport and Hardinge Mills 1 07-10-2006 08:07 AM
Bridgeport Discovery 308 SX-15 CMOS lost time and settings Richardd Machine Problems, Solutions , Wireless DNC, serial port 0 06-22-2006 07:01 PM
