I have trouble with my Interact 418/TNC 2500 from 1990 ... Please help me, I have trouble with : "RELAY EXT. DC VOLTAGE MISSING" (Switch ON machine - CE button - orange DC button and nothing - only message "RELAY EXT. DC VOLTAGE MISSING") I suppose trouble with 24 V, but I do not know if it is good way... Have someone Circuit digram DRG No. 240-109 SHT.2 (I have only SHT 1) ? Thank you, Zdenek mailto:zdenek@hales.cz |
| If you turn the machine ON with the EMERGENCY BUTTON pushed in, you will get this alarm. And if you have a 24VDC power supply issue, you will also get this alarm. Is your emergency stop button pushed in? George
| My emergency button is not pushed in, it is in "ready" position. Switch is OK-not damaged. Is in push in position of emergency button on contact switch 24 VDC? Yesterday when I switched on machine, I pulled up emergency button to ready positon and pressed "orange" DC button and TNC message was still only : RELAY EXT. DC VOLTAGE MISSING Today I will try verify 24 VDC. Thank you, Zdenek |
| I once had this problem when i was not turning the drives Swith ON only because I was ignorant to Heidenhain. It is not a major problem.You must notice that the drives are not powered yet when your drives will be powered On this message will disappear. George is very cooperative He will help you out. Alee |
| Turn machine on with the Emergency Stop button pulled out. If you still get the same alarm, you do have a 24VDC issue. If you no longer get this alarm and If the drives will not stay on press and hold in the yellow button and jog the axis away from the ends of travel. George
| Mine did that when I moved it from my friends house to mine. Same phase convertor but the voltage at my house was a little different. Changed the transformer taps and fixed it. Later I boxed in my phase convertor (rotary) to kill the noise it makes. After my first long milling session the box caused the RPC to overheat and ruined a capacitor. My mill displayed the message you got. My Fix: Have the RPC guy check out the RPC and he replaced the damaged caps. I've also had a problem when the tables are parked on the limit switches. I can't remember if it throws this error code or not... On my machine the fix is to manually screw the steppers off the limit or on my control hold the green and yellow buttons in and drive the table off the limit with the joystick. Everytime the old girl errors out I have a dreadful feeling she won't come back... Tough to fix a 1989 computer! |
| It was power supply failure. One phase has a little different voltage lower. Now is machine OK. Thank you to all for cooperation ! Can you help me with message. please : CYCLE BUTTON RESTART SPINDLE. Sometimes spindle stop a I must press cycle button. What causationis it ? Have someone Circuit digram DRG No. 240-109 SHT.2 (I have only SHT 1) ? Thank you. |
#11
Hello all, Thank you for your group and I am happy to be here. I have a question. I have a Heidenhain TNC 430 on a Jo'Mach 23 and recently I have been getting the "Relay ext. dc voltage missing" but even before the "Power Interrupted" screen, and it's in the form of a red box with blinking title. Nothing I do clears it but the end. All E stop circuits and 24v lines check out fine.. What can it be? |
| Bridgeport Interact 1 MK2 - Input Voltage | palikalsi | Bridgeport and Hardinge Mills | 20 | 11-07-2008 07:42 PM |
| Missing .DLL??? | CyborgCNC | Surfcam | 6 | 05-25-2007 12:41 PM |
| Am i missing anything here? | phantomcow2 | General Electronics Discussion | 7 | 08-11-2005 10:36 PM |
| Not sure what i'm missing? | Gnome | Gecko Drives | 3 | 03-27-2005 06:55 AM |
| Some of my buttons are missing??? | boxwood | Forum Questions or Problems | 2 | 05-17-2004 07:00 AM |
