This alarm appears after I have run a program through the first time. I want to rerun lets say an end mill through again to bring maybe a slot to size. I do a tool search or maybe a sequence number search to this particular portion of the program. Sometimes I get this z parse command too far positive alarm around the areas of a canned cycle such as G81 or G83. I go back through and edit the progam taking the canned cycle out and then have no problems with a tool search or sequence number search to the correct tool I want to rerun. This is a Bridgeport DX-32 VTX2 milling machine. I have a good bit of CNC experience with Haas, Hardinge, milling machines and lathes, but this alarm has me baffled. I am not too familar this Bridgeport DX-32 |
| Just because you search to a line does not mean everything it has seen so far is active. It may not have the proper Tool Length Offset for the commanded line. Example: You turn a machine on. Z zero is that the quill is up. You do not call up a tool and a TLO. You go to a drill line where the command is to go .050 above the part. The quill is already up and at zero thus it cannot go up any further. Z axis alarm! George
| Global Warming a positive spin | Shotout | Environmental & Alternate Energy | 6 | 07-04-2007 11:56 AM |
| On the Z-axis, All Movement Above Zero Are Positive - Right? | TheNigerian | Machines running Mach Software | 3 | 05-22-2006 08:46 AM |
| Positive I & J in lower quadrant | orbimachine | BobCad-Cam | 2 | 02-23-2006 01:14 PM |
| Macro for positive offset | qmas99 | General CAM Discussion | 0 | 02-11-2006 09:37 PM |
| 2004 a positive? | KBW | General Metalwork Discussion | 3 | 12-18-2003 04:51 PM |
