Old 06-29-2007, 06:20 AM
hmc710 is on a distinguished road
Brake rebuild
Hi All,
I have a Bridgeport Interact II with Heidenhain TNC145 control (thanks for all the input on that by the way) and the brake doesn't work. I've rebuilt the brake on my Enco which has the variable speed drive and the manual for my BPT looks similar. Any advice or tips before I start this repair?
Thanks in advance.
Tim
Old 07-01-2007, 01:02 AM
swarf_rat is on a distinguished road
It is a series 1? That is, no DC drive, but vari-drive?
If so it is straightforward. The parts inside are all identical to a manual J2 head, you can use that exploded diagram available on the web at places like www.mataco.com. Difference being the housings themselves look different, and the fact that the motor is mounted upside-down.
Old 07-02-2007, 01:03 PM
Brake
Our machine is a series II with the vari-drive. I've been printing out info on it before I start digging into it.
Old 07-02-2007, 10:33 PM
Sorry, should have asked Mk 1? I think the Series II is the same as the Series 1 once you get above the column. And the same as a 2J except for the upside down motor and different housings.
Foamcutter Rebuild OzDragonflyer CNC Wire Foam Cutter Machines 14 10-11-2007 04:09 PM
2J head rebuild, What did I miss?? Stillearnn Bridgeport and Hardinge Mills 1 10-25-2006 02:21 PM
rebuild linear bearing DrStein99 Linear and Rotary Motion 0 05-12-2006 08:52 PM
Haas Vf-2 Rebuild DEAN Haas Mills 7 09-18-2005 10:46 PM
Router Rebuild Ursine DIY-CNC Router Table Machines 0 08-18-2005 08:42 AM
