Old 06-12-2007, 01:25 PM
bherr is on a distinguished road
Question Which Hydraulic Oil do I use?????
To All (Newbie) no machine manual! I had to disconnect the hydraulic lines to remove my spindle motor and I'm trying to bleed the line, but out of hydraulic oil. What type do I need to use or will any hydraulic oil do??
Thanks for your assistance
Ben
Old 06-12-2007, 04:38 PM
Al_The_Man's Avatar
I have been told in the past that it is not so much what you use but the viscosity should match the application/temp range, there are Hydraulic supply reps. in most large towns, maybe look thorough the phone book for a local one to advise you over the phone.
Old 06-12-2007, 08:01 PM
Smile Hydrualic Oil
Got it guys and thanks.
Ben
hydraulic chuck Runner4404spd Mini Lathe 9 02-11-2007 04:46 PM
Hydraulic pump and motor? DennisCNC Mechanical Calculations/Engineering Design 16 07-28-2006 12:30 PM
HELP - How to service a hydraulic vice. Chad Cappa General Metalwork Discussion 4 11-20-2005 09:12 AM
Where to buy Rexroth Hydraulic valve? mjse CNCzone Club House 1 07-23-2004 07:28 AM
