Old 06-11-2007, 04:30 PM
bherr is on a distinguished road
Trouble w/ air tool holder????
Guys,
Had my DC spindle motor reworked and now I'm having trouble getting the air tool holder to work. I've attached two photos. The first photos shows a switch which rides on the arm just below it, which keeps the switch closed to move the Z spindle. If I try moving it without this switch closed the machine shuts down and I have to turn off the power and then reset the controller.
the second photos show a unit which I can't quite figure out what it does. I had to disconnect the air line in order to remove the spindle motor out the back. Now when I try and install a tool it doesn't get any air to pull or push the tool holder. the air line (large black hose in photo #1 run to a "T" which goes down to the lifter arm just below this micro switch and then over to the top of the cylinder in photo #2 and into its top. At the bottom you can see a large bolt which rides on the top of the spindle shaft and this unit has a long bolt which rides on the spindle shaft. It will ride up and down, but can't figure out how its activated. Any help would be greatly appreciated. Note: the second photos show a orange light which is lite and a green lite not lite. I've added a third photo which shows the entire air system.
Ben
ID:	38844   Click image for larger version
ID:	38845   Click image for larger version
Old 06-11-2007, 05:37 PM
Moderator
machintek is on a distinguished road
Looks like an INTERACT 4. It has a hydraulic cylinder to release the tool. In the cabinet there should be a air over oil cylinder. There cannot be any air in the hydraulics.
When the cylinder actuates, it pushes a paw that has a switch on it. This paw engages and holds the Z axis pulley from moving thus the quill is not forced down and the hydarulic stroke is not lost. Also the switch disables the Z drive so that it does not work against the cylinder and does not fault out.
George
Old 06-11-2007, 06:47 PM
air tool problem
What does it look like and is it in the photo? How do I check for air?
I've attached photos inside of cabinet, which one is it.
It is an Interact 4 Series II
Ben
ID:	38853   Click image for larger version
ID:	38854   Click image for larger version
ID:	38855   Click image for larger version
Old 06-11-2007, 08:39 PM
Moderator
I have to find a maintenance manual on an INTERACT 4. The ones I worked on, has a large air cylinder pressing on a smaller Hydraulic piston somewhere at the base of the machine. The draw bar will require almost a ton of force to remove the tool. Then I can scan that part and post it. Follow the hydraulic hose to see where it goes. What you are showing me are the air filter, regulator and air line oiler.
George
Old 06-12-2007, 10:45 AM
George
George,
Check photo # ending in 17 in first post. Is that the hydraulic cylinder you are referring to?? Also if you find a maintenance manual, could I get you to make a photo copy for me, Glad to pay your time and costs.
Ben
Old 06-13-2007, 09:40 AM
Moderator
Attached is a page that shows what should be in the pneumatics cabinet.
Item 27 is the booster that I referred to. It uses a large air cylinder working against a small hydraulic piston to create enough pressure to release the tool by use of the hydraulic cylinder in your first set of pictures.
There is no reference in the manual to any maintenance on this unit.
George
Old 06-14-2007, 08:53 AM
UKRobotics is on a distinguished road
Here is a photo of the thing you are looking for:
Out of interest, if the hydraulic actuator is used to remove the tool, what mechanism holds it in place and stops it from falling out in use?
Dom
http://www.ukrobotics.com/projects
Old 06-14-2007, 11:06 AM
gus gus is offline
gus is on a distinguished road
re
probably springs, most retention knob holders use springs
Old 06-14-2007, 07:12 PM
Moderator
A atack of spring washers inside the spindle.
George
Old 06-15-2007, 07:50 AM
So to change the tool I would have to hold down the tool release button, take out the old tool holder, put in the new one, then release the button and the ram would retract leaving the springs to hold it in place ?
Dom
Old 06-15-2007, 06:34 PM
Moderator
Correct. This is the way all CNCs work that have tool changers. They have a stack of spring washers inside the spindle. Newer Daewoo/Doosans have a gas cartridge instead of the spring washers. But the cylinder is fired at the right time by the control. Even the old Bridgeport BTC1 has this stack of internal spring washers.
George.
tool post holder omegaghost General Metalwork Discussion 1 05-09-2007 07:25 AM
tool post holder omegaghost General Metalwork Discussion 1 05-07-2007 07:43 PM
Tool Holder -- CAT 40 (ANSI) Chivo General Metalwork Discussion 13 06-24-2006 01:22 AM
Tool holder trouble an0n General Metal Working Machines 4 04-06-2005 10:43 AM
tool holder corrie DIY-CNC Router Table Machines 2 07-23-2004 04:04 PM
