Old 06-10-2007, 12:36 AM
palikalsi is on a distinguished road
BP Interact 1 MK2 - TNC 2500 Axis Acceleration
Hi all,
I need to know what acceleration rates others are using for this machine. I have the machine with TNC 2500 and my acceleration is set to .03 MM/S for all three axis and the speed at corners is set to 1 (option can be set anywhere between 1 to 90). Basically, I want to eliminate jerky movements that my machine gives when there are multiple linear movements with sharp corners and would like to know what settings others use for these parameters.
Does anyone have the parameters for Interact 1 MK2 - TNC 2500 or maybe even know what acceleration is ideal for this machine?
Thanks and regards,
Pali
Old 06-12-2007, 08:31 AM
greg b is on a distinguished road
Reply to parrameter settings
Pali on my interact 1 mark 2 2500 control my setting are as follows
Acceleration 1060/0
1060/1
1060/2
1060/3 are all .2
Radial Acceleration
1070 is .2
Constant contouring speed at corners
7460 is 2
Hope this helps mate regards greg b
Old 06-12-2007, 10:05 AM
Thank you greg. I will try to update the Constant contouring speed at corners and see if that helps eliminate the jerky movements.
Regards,
Pali
Bridgeport Serier II Interact 4 (Heidenhain TNC 2500) elhosseiny Bridgeport and Hardinge Mills 2 08-10-2011 10:54 PM
Heidenhain tnc 2500 on Interact 308 GarageShop Bridgeport and Hardinge Mills 16 12-15-2010 04:57 PM
Heidenhain TNC 2500 in Interact 308 GarageShop Bridgeport and Hardinge Mills 12 08-24-2008 04:16 PM
Bridgeport Interact 1 MK 2 TNC 2500 control JohnPW Bridgeport and Hardinge Mills 9 05-13-2007 10:50 PM
Oscillation During Axis Acceleration Geof Haas Mills 4 07-18-2006 04:29 PM
