Old 06-09-2007, 06:32 AM
Jonne is on a distinguished road
BP CNC S1 Speed control with Mach3?
I have BP CNC S1 with pneumatic varispeed head.
Can I, or is it difficult to make mach3 controlling speed?
Any ideas?
Johannes
Old 06-11-2007, 11:41 PM
phomann's Avatar
phomann is on a distinguished road
Any ideas?
Johannes
Hi Johannes,
I'm not familiar with this machine. Tell me, how do you manually vary the speed on it now? Is it done via a pneumatic valve?
I designed and sell the DigiSpeed range of speed controllers. Maybe I could do a mod, or a special one to help you out.
http://homanndesigns.com/store/index...=index&cPath=1
Cheers,
Peter.
Homann Designs - http://www.homanndesigns.com
Old 06-12-2007, 02:40 AM
It's use pneumatic solenoid valves (24 V). These valves controls
pneumatic turbine what uses via worm gear variators speed change plate.
Please answer my E-mail.
Johannes
johannesthelen@hotmail.com
Old 06-18-2007, 02:31 PM
creep_pea is on a distinguished road
Hi Johannes
Did you get anywhere with this?
I'd of thought it would be easily possible and if you put a speed sensor on the spindle it should be possible to write a macro that will alter the speed to the programed speed.
Cheers
Chris
Spindle speed and tach for MACH3 chrispy Mach Software (ArtSoft software) 16 04-05-2008 08:25 AM
Speed control ? deleteallusers G-Code Programing 3 05-10-2007 01:48 PM
BPSeriesI / Centroid control- Spindle speed all out of whack with speed dial? peter.blais Bridgeport and Hardinge Mills 9 08-08-2006 03:29 AM
PIC R/C speed control? DennisCNC PIC Programing / Design 1 04-01-2006 01:22 AM
Stepper motors are still going at the incorrect speed. Need help with Mach3 Apples Mach Software (ArtSoft software) 5 12-23-2005 05:29 PM
