Old 06-04-2007, 03:52 PM
bherr is on a distinguished road
Exclamation Brushes look Good ????
OK,
I finally got the motor pulled out far enough from the casting to really get a good look and discovered that the brushes look pretty good, I think. the second photos shows a lot of greease or oil on the brush connectors, so you think this could have been causing my spindle to shut down during cycle runs? I have pulled the Tacho to check those brushes yet, but curious on the photos attached. Need your opinions.
Thanks,
Ben
ID:	38565   Click image for larger version
Old 06-04-2007, 04:07 PM
Al_The_Man's Avatar
The brushes look a good length, you had mentioned in the other post that one had completely gone?
Grease is never good on brush gear, the grease becomes a carbon mixture and can be conductive to cause ground faults. As someone mentioned the Commutator looks worn, if you have gone this far it may pay to pull the armature and get the comm turned, some modern commutators do not need undercutting, the insulation between the slots wears with the copper, the older (and some current) motors used mica between the comm bars and this needs cutting down below the newly turned level. This can be done by hand with a hand made tool or there are electric ones available.
Old 06-04-2007, 05:21 PM
Brushes
Thanks Al, the problem I was having was the spindle intermittenly shutting down in a cycle run. I wasn't looking in the right spot for the brushes, so they are all good, like in the picture. I do have replacement brushes for the Tacho, but haven't taken it off to inspect them yet. I think you and others are right, since I have the motor this far removed, I might as well take it all the way out and get the commentor milled down.
Ben
Dust Collection and Brushes Gibbon DIY-CNC Router Table Machines 11 01-14-2012 12:31 PM
dc motor brushes supplier DrStein99 Mechanical Calculations/Engineering Design 16 05-01-2007 10:22 PM
Replacement Brushes For VF-1 problem GITRDUN Haas Mills 7 03-07-2007 10:24 PM
Strip Brushes GVP DIY-CNC Router Table Machines 2 01-13-2007 06:17 PM
xtra motor brushes smarbaga Servo Motors and Drives 2 12-08-2005 02:31 PM
