Old 05-31-2007, 08:15 PM
contractdesign is on a distinguished road
rapid speed
Just curious, I have a 1985 boss 5 with a mach 3 retro, original steppers. I run my rapid (g0) speed at 50 ipm. I am curious what rapid speed others are running on a similar machine.
Old 06-01-2007, 07:57 AM
gus gus is offline
gus is on a distinguished road
didn't it originally do at least 100?
Old 06-01-2007, 08:40 AM
wcarrothers1 is on a distinguished road
I've only jogged around with mine so far playing and getting things setup but I've seen it do 200+ jogging. That is screeming fast to me seeing I only have my round pole conversion set to ~50 fast. My router mill does 400/200 fast depending on he axis..
but to see a 40 some " table move that quick looks real fast..hehe
I think with the gecko conversion you would have to limit your top speed to what ever breaking speeds your gecko's could handle (slowing down that much weight) with out breaking any of the electronics inside. Not sure if a break resistor would be needed or a good idea. If I ever convert mine to gecko control it's something I'd have to look into and know others have talked about it.
no idea how that would be calculated though.
b.
Old 06-01-2007, 11:38 AM
gus gus is offline
It won't seem fast soon.
Watch my big machine run at 2750ipm and everything else is just pokey
Truthfully, accel and decel are where real speed can be found. If you can get the ramps to run fast, you will see real throughput increase
Old 06-01-2007, 12:48 PM
The trick is to be able to feed work to a fast machine that fast..hehe
b.
Old 06-04-2007, 07:58 AM
creep_pea is on a distinguished road
I'm running mine at 2010mm/min (80ipm). Boss 6.1, metric machine, original drives and steppers running off Mach3 so not sure if it's comparable.
Old 06-04-2007, 09:23 AM
gus gus is offline
dunno how you guys stay awake waiting for your machine to be done......
Rapid to (# set by Parameter) What's yours? Scott_bob G-Code Programing 8 07-13-2009 07:05 AM
G-Zero by Rapid Output!!!!! tobyaxis General CAM Discussion 0 02-04-2007 10:16 PM
Rapid moves G00 dicksonhof Mach Software (ArtSoft software) 9 11-07-2006 09:21 AM
BPSeriesI / Centroid control- Spindle speed all out of whack with speed dial? peter.blais Bridgeport and Hardinge Mills 9 08-08-2006 03:29 AM
New Taig, 8 ipm maximum rapid speed? fivaxis Taig Mills & Lathes 5 05-11-2006 08:55 AM
