Old 05-29-2007, 04:18 PM
AbleGear is on a distinguished road
Please help with vari speed!
Hello,
I have a 1980's J Head series one cnc with a air driven vari speed on it. When I was going to indicate a workpiece, I had the machine in low range, and turned the speed all the way down. However, I left the decrease button on too long. There is a slight metallic sound now and the speed will not increase again. I am new to the vari-speed, am I overlooking a very simple fix or is this a rare problem?
Thanks for any advice
Brian
Old 06-04-2007, 01:30 PM
bigbaz is on a distinguished road
had a similar thing go on my machine, when i pressed the button to make it slower it kept going after i remove my finger so i had to press the faster button to stop it, when i inspected the pnuematic valve block the shaft has a circlip on the end of shaft and this had come off, once back in place worked fine again. can you hear the air leaking.
Old 06-04-2007, 04:49 PM
Moderator
machintek is on a distinguished road
It may have bottomed out and is jammed. The scraping may be the plate that pushes down on the front adjustable vari disc.
The air motor is held to the mounting tube with a few set screws. You can back them up, pull the motor, and use a screwdriver to turn the coupling, thus releasing the pressure and getting it back to a working state.
Behind the spindle speed dial is a set screw that goes through an the belt housing and fits in a groove in the gear that winds the chain. I have seen the roll pin stop in the gear broken. Just some more data.
George
Belt Replacement vari speed jlv3901 Bridgeport and Hardinge Mills 3 07-24-2007 07:25 AM
HF 8X12 Vari-speed Ed Boysun Mini Lathe 13 03-06-2007 04:03 PM
BPSeriesI / Centroid control- Spindle speed all out of whack with speed dial? peter.blais Bridgeport and Hardinge Mills 9 08-08-2006 03:29 AM
2 hp to 1.5 hp motor interchange on vari-speed head?? wdbdel Bridgeport and Hardinge Mills 5 12-15-2005 09:34 PM
min speed exceeds max speed for axis "x"? ljoe1969 TurboCNC 4 01-19-2004 07:49 AM
