Old 05-24-2007, 06:58 PM
Dar Dar is offline
Dar is on a distinguished road
Cool problem bp2tnc145
well hi guys
here i go again. i have 2 seperate programs in the machine. they are seperated by a few lines. when i call up #1 it runs fine when i call up #2which is line 20 it runs fine[[[sometimes]]] but at times when i call 20 #1 runs and viceversa .does anybody have any ideas.keep in mind that i,m very new at this but i don,t think i,m doing anything wrong. thanks for any suggestions.
Dar [frustrated]
Old 05-25-2007, 06:56 AM
gus gus is offline
gus is on a distinguished road
re
You must not be keying it in properly. It quite literally cannot do what you describe. On the 145 You enter the number into the register[the little blue numbers] and press GOTO fterwards. The number will stay stored in the register until you enter something else. My guess is that you are not proeprly clearing the first number and it is GOTOing to the beginning, or tha that you have an M2 in there somewhere sending it back to block one
Old 05-26-2007, 08:46 AM
Dar Dar is offline
Talking problems
thankyou thankyou Gus
you are right iwas keying it wrong . i thought i had to hit goto and then the number. it sure works a lot better when i do it right.
thanks again Dar
Old 05-26-2007, 12:14 PM
gus gus is offline
re
You were half right, all the newer controls are backwards, so when you get a newer one, you will mess it up all the time[ask me how I know.........]
G52 Problem j-radkemachine Haas Mills 1 04-19-2007 05:09 PM
VMC 10 problem hpm Fadal 0 04-17-2007 09:59 AM
The G01 & G71 problem!!! Darkos General Metal Working Machines 3 08-24-2006 03:12 PM
Problem impact Xylotex 1 03-12-2006 12:53 PM
Problem - Need Help gary-cook Mach Software (ArtSoft software) 1 06-09-2005 02:55 AM
