Old 05-23-2007, 02:44 PM
pwe169 is on a distinguished road
help p/s 224 error
Hi all,
I have a bridgeport vmc1000II 3 axis mill with fanuc control. Whilst dnc controlling it this evening it stopped operating. After I reset it I get a p/s error 224 when I attempt to run any code. I cant even do a m06 via vmi - error 224 comes up which after a few minutes is followed by a m06 time out alarm.
Does anyone have any ideas???
As usual this has happened as I am doing a rush job!!!!!
Pete
Old 05-23-2007, 06:20 PM
Moderator
machintek is on a distinguished road
Look in the FANUC maintenance manual. It has an alarm list.
Or call FANUC. They are very helpful.
George
Old 05-24-2007, 06:06 AM
Thanks for the answer. Checked that but the Fanuc manual goes up to 128 then starts again at 300 so I think the fault must be Hardinge specific. However I started the machine again this morning and the fault is now clear. Any more ideas?
Pete
Old 05-24-2007, 06:44 AM
Moderator
Some faults associated with the drives are fatal and require a power off. Some may be thermal. Thus a cool down could get you going again. When I get a few minutes at the office, I will do some digging.
Also , try not shutting your machine off and looking at the fanuc units for an alarm code.
George
tl-2 program integrity error and program data error alarm #'s 212 250 need help CNChelp Haas Mills 12 03-14-2010 08:19 PM
What is this ERROR? Capt Crunch Mastercam 6 06-02-2007 04:49 AM
sum error 2 gotis Mazak, Mitsubishi, Mazatrol 5 03-09-2007 07:32 AM
I am getting a error now fastolds GibbsCAM 2 08-28-2005 07:18 PM
