Old 05-10-2007, 11:38 AM
JohnPW is on a distinguished road
Smile Bridgeport Interact 1 MK 2 TNC 2500 control
I have literly screwed up the parameters in this machine. I have a parameter listing that came with it, but it must be for a different machine.
We are not using the fourth axis.
I loaded up the parameters as on the lists; someone added changes in ink, to the list numbers I thought was updated on this control. I saw several parameters that weren't the same and of course didn't write them down, shame on me. The maching has not been run in 1 1/2 years and I thought the parameters were scrambled. So I changed them to what was on the sheet. Now I get a 'B encoder feedback irregular A' and it hangs the control with tons of lists undernieth it. I think somehow I activated the fourth 'A' axis which is not connected. So getting a fault from it.
What I would like is a list of parameters from a working machine that is not using the fourth axis. So I can see what is different. Or does anyone have a parameter listing book that tells what these parameters actually do. Then I could figure out where I went wrong. I will share what info I have, if I could get it. the machine is presently down.
I also noticed that the periods all are comma's in the parameter list. Does this mean there are other issues? The batteries were dead. How do I recover? Everytime I press a period I get a comma displayed.
As to the question about the spindle drive not running, I changed out the drive to a ten horsepower Baldor AC drive, the machine when it runs, runs beautifully. I have the prints on what to do if you are interested. I inverted the AC motor so it was sitting up from the spindle mount, not in the column, as the original DC motor was sitting. There wouldn't have been room for a 10HP motor there.
If anyone could get me a list of the correct parameters for this machine I would greatly appreciate it.
Please email me at johnpw@en.com
Please put Bridgeport in the header message
Old 05-10-2007, 04:16 PM
palikalsi is on a distinguished road
John,
I have the same exact machine and attached are my parameters. Hope they help.
Regards,
Pali
Old 05-10-2007, 04:39 PM
Moderator
machintek is on a distinguished road
Please remember that there were many revisions to the 2500 control. The original release was version 3, the last released by Bridgeport was version 12. Each had a different parameter list. The control version was changed by replacing PROMs in the control.
George
Old 05-10-2007, 07:22 PM
bridgeport Interact 1 MK2 TNC 2500
George
Thank you George for that, I didn't note what revision I have but I will tomorrow. I will let you know.
Thanks for your help.
John
Old 05-10-2007, 07:26 PM
Smile
Originally Posted by palikalsi View Post
John,
Regards,
Pali
Thank you for your parameter list. It is very similar to what I presently have. So now I have to go through them to see what changes I have to make. I assume you do not have the fourth axis connected? Correct?
I believe my error is because of it thinking a fourth axis was to be connected.
I wish I knew what all the parameters really stood for, for then I could figure it all out myself from scratch.
But what you gave me should help I hope.
Any chance you know why I get a comma instead of a period when I press the period key on the keyboard when I change parameters? Do I have to reset something?
John
Old 05-11-2007, 06:31 AM
Moderator
The comma is default. It can be changed to a period. On the older controls certain canned cycles would not work with a period. I am not sure about the 2500.
George
Old 05-11-2007, 06:39 AM
gridley51 is on a distinguished road
Here is a link to the manuals.The meaning of the parameters will be there.
http://filebase.heidenhain.de/doku/o...91/N13F91.html
Old 05-11-2007, 07:20 AM
greg b is on a distinguished road
George just out of interest in what year did they stop making the 2500 control, mine is married to a interact 1 mark2 with a ktk controller.Regards greg b
Old 05-11-2007, 10:23 AM
Talking Bridgeport Interact 1 MK2 TNC 2500
Thank you very much. The Technical manual did the trick as well as the parameters I recieved. I see what I did wrong and saw I activated the fourth axis by mistake.
Hopefully I will be able to get my machine running again. Thanks to everyone that have supplied all the information here. This web site is awsome. I'm glad I found it.
I had a call in to Bridgport service department, and it has been three days and have yet to hear from them. I assume no one is there anymore that knows these machines.
This forum had answered the questions I had, and it is definately more responsive than the manufacturer.
Again, Thank you everyone.
John
Old 05-13-2007, 10:50 PM
I want to thank everyone that replied to my message. I did get the problem resolved. the machine is running fine. It was a few parameters that were wrong.
Thank you everyone
John W
can anyone help with heidenhain 2500 control parameters? greg b Bridgeport and Hardinge Mills 14 02-21-2012 07:43 AM
Bridgeport Serier II Interact 4 (Heidenhain TNC 2500) elhosseiny Bridgeport and Hardinge Mills 2 08-10-2011 10:54 PM
Heidenhain tnc 2500 on Interact 308 GarageShop Bridgeport and Hardinge Mills 16 12-15-2010 04:57 PM
Heidenhain TNC 2500 in Interact 308 GarageShop Bridgeport and Hardinge Mills 12 08-24-2008 04:16 PM
Bridgeport Interact 412 w/Hedenhain control. Good machine? SRT Mike Bridgeport and Hardinge Mills 3 06-25-2006 08:13 PM
