Old 05-10-2007, 11:31 AM
cut more is on a distinguished road
BOSS 8 problem
Hello,
I recently aquired 2 series2 r2e3's with BOSS8 Controls, The controls work, the axis home & jog fine. I am using a phase converter for the 3 phase. Everytime I try to start the spindle the control seems to either fault, or re-sets as if the voltage drops too low. I have checked the terminals for the lube switch & that is closed. Is there any reason not to supply 115v to the circuits from my garage wiring rather than using transformed 220v to 115V?
Thank you for any help,
Cutmore
Old 05-14-2007, 07:15 AM
Spindle start problem
Just bumping the thread, Any one have a suggestion?
Thanks for any help.
Cutmore
Old 05-14-2007, 07:56 AM
afmcorp is on a distinguished road
boss 8
hello
first off not all phase converters make a constant 3rd leg. what u need to do is to start ur converter and test each leg. the generated leg drops to say 50 volt u have the wrong type. i am assuming ur using a rotary style. u need one like GWM.
u should be supplying the phase converter 220/240 v single phase [pls see my "BUT" to follow]. i would strongly suggest not applying and other or additional power source. just get rid of the transformer and use a 220v breaker switch. then use a true 3rd leg rotary phase converter and if the controller works then this setup should work fine.
BUT don't do anything else till you confirm what power ur machines need. look on the rear cabinet it will tell u what u need.
good luck
Old 05-14-2007, 08:16 AM
Thanks for the reply,
I am supplying 220v, I am using a rotary, The machine is set up for 230v( the transformer taps were set there when I got the mill)
I am confused by "i would strongly suggest not applying and other or additional power source. just get rid of the transformer and use a 220v breaker switch."
Did you mean to supply 220 to the transformer directly and use a disconnect? The transformer is a stepdown to 115v so why not just supply 115v? Or maybe I mis-understood you.
Old 05-14-2007, 02:04 PM
bp
i probably misunderstood you. but what i was thinking is you were going to add another 110v line.
the important part is that the phase converter shows full voltage when you go across legs. some i think when going to ground may show some wild voltage or maybe i'm reversed. anyway all 3 legs must have full voltage period. you'll have 3 hot and 1 grd. so go across the 3 legs and to ground to verify.
you'll want to make sure u have the cmos batteries fresh. they are on the left side of the head behind some panels. again i am assuming this is a ridged ram style which is what i have.
the part i like about my r2 is you can set it up to read the old boss 7 and back programs. i use my boss 5 programs all the time. i have the r2 set up to read both an xp computer and the old stand a lone 5 1/4 box that came out when they were first made.
good luck
Old 05-14-2007, 04:56 PM
gguidi is on a distinguished road
Power
I have the same machine. I had a phase converter set up and I had the same problems. I added a variable frequency ac drive to run the spindle and am running the drives and the logic on 220 single phase. It took a little rewiring but it runs well and with out all of the converter noise. I also found that the drives are very over voltage sensitive. I was getting faults and tracked it to the voltage being high to the drives.
Gary
Old 05-15-2007, 05:35 AM
Thanks for the help guys,
What program do you guys use to send/receive files to your boss controls? I have not had time to even try that yet. I was wondering if bobcad can communicate or will I need software for that?
Cutmore
Old 05-15-2007, 12:47 PM
Smile boss 8
guys
your boss 8 and up are critical on electric currents etc:. it is far better to run the correct rotorary phase converter. if none of the previous owners screwed around and the wiring is intact from the factory just get the converter you'll have better luck doing repairs.
my 1st cnc was and excello with a bandit [dana] controller. i tried a phasamatic because the mfg said it would work. well it didn't. the 3rd leg fell off to about 50 volts. the motor did ok but the controller wouldn't work. that is because the controller only needs single phase but it takes that from all 3 wire leads and then does various transformer functions and isolations to make it work. i had to rewire the controller to get it to work because i said to heck with it and got a static ph conv that has no 3rd leg. well it worked fine except i lost the M02 function so i had to hit the clear button after each run but NBT. when i got my 1st boss i went to a GWM converter that gave me a constant 3rd leg and it worked just like it was supposed to. i ran that whole shop on a 100 amp single phase power. 2 cnc mills, 1 man mill, 2 lathes and 2 horz and 1 vertical saw, 7hp compressor and a 150amp welder. got to know electrical circuits fairly well.
good luck
Old 05-17-2007, 09:23 PM
Newby2 is on a distinguished road
I am running my R2E3 BOSS 8 II on a 7.5 hp phase convertor. Although the spindle motor is only 2 hp, the added capacity of the convertor will allow additional equipment to be run.
I have no problems with the controls dropping out with this arrangement.
Steve
Old 05-18-2007, 07:20 AM
steve
pls post the brand of rotory conv u have
tks
craig
  #11   Ban this user!
Old 05-18-2007, 10:52 PM
Craig, I need to backtrack on the hp of the converter. After reveiwing the specs of the converter, it is a 5 KW.
Brand name is TEMCo (Tower Electric Motor Company) Model 6500-5KW.
I purchased it direct from the company (thru their website www.Phaseconverter.com ) new for $700 delivered with a 6 year warranty.
Steve
  #12   Ban this user!
Old 05-19-2007, 01:42 PM
steve
thanks for the reply. that 5kw is probably 5kva. has to do with the measurement of output. i also wanted the guys here to see about rotary phase converters. 5 kva is the same size i eventually got for my 1st rram
tks
craig
i stand corrected that site is calling it 5kw. transformers and ro conv always well i guess almost always defines the size by kva.
Boss 6 Axis Problem DaveinUK Bridgeport and Hardinge Mills 2 02-21-2007 10:06 AM
Boss 6 Problem ?? DaveinUK Bridgeport and Hardinge Mills 13 07-25-2006 11:04 AM
Boss 9 z axis problem Drewboy Bridgeport and Hardinge Mills 4 03-28-2006 07:53 PM
Problem with the 5 volt supply (Boss) creep_pea Bridgeport and Hardinge Mills 8 01-20-2006 03:19 PM
Boss 5 Y axis problem? jeaBOSS5 Bridgeport and Hardinge Mills 8 12-11-2005 03:40 PM
