Old 05-02-2007, 09:54 PM
md63825's Avatar
md63825 is on a distinguished road
DXF Import on EZ-Plus
Does anyone know how to use the dxf import tool on the Bridgeport EZ-Plus system? I can import the dxf file but when I go into EDIT and toggle to the dxf files and select the dxf file, I get the following message "could not find file psurf".
Old 05-03-2007, 06:44 AM
Moderator
machintek is on a distinguished road
Never done it but check the book on the rules. Cannot exceed the size of the screen and has to be enclosed (I guess have all sides touching making a continuous shape), etc.. I just remember this from long ago.
George
Old 05-03-2007, 09:32 AM
Dennis Storzek is on a distinguished road
I don't use EZ-Plus, but have done a lot of work with AutoCAD, although I'm a bit behind the times as I've refused to update past R13. It sounds like the DXF file converter is trying to find a surface fill or something (PSURF is not defined in the R13 documentation). This happens to me occasionally when bringing AutoCAD files with text into MasterCAM, but MasterCAM has an error routine that gets past it.
Try importing the DXF file into AutoCAD and use ACAD's EXPLODE command to break everything down to arcs and lines, deleting any fills or surfaces that EZ-Plus can't interpret. Then try importing the modified file to EZ-Plus.
Dennis
import DXF qmas99 FeatureCAM CAD/CAM 1 07-19-2006 07:08 AM
Anyone here import from China? Smertrios CNCzone Club House 12 04-11-2006 08:25 AM
Import plasma's ....here they come carbidecraters CNC Plasma and Waterjet Machines 0 03-03-2006 04:12 AM
Import from Rhino HELP!!!! allen_d Mastercam 2 10-12-2005 12:52 PM
DXF Import Todd Price Rhino 3D 5 06-07-2004 12:24 PM
