Old 05-01-2007, 02:06 PM
bherr is on a distinguished road
Question Spindle keeps shutting down during program
My BP series II interact 4 keeps shutting down during a cycle run. It seems to run fine for several milling's and then all of a sudden it just stops. I've had several members suggest possible causes and this is why I'm looking to purchase a manual for my machine. I running Cantraves controller with Heidenhain TNC 155b. I checked the voltages over the three legs, but not while the machine is running. someone suggested that the brushes in the motor maybe getting worn and if the spindle fluctuates due to worn brushes, this may cause my spindle to shut down. I can't continue to operate this way as it takes forever to get anything done. so I'm again looking for a manual and any help.
Thanks in advance,
Ben
Old 05-01-2007, 02:25 PM
Al_The_Man's Avatar
Someone may have already commented on this, but I assume if it is three phase in and a DC spindle, it is probabally an older SCR bridge type, Most of these types come with status lights etc or even a 7 segment display?
Is there any other indication on the drive etc of this kind, is it a wound field motor?
Old 05-01-2007, 04:18 PM
Spindle stops
Al,
I don't have the faintest idea. I've attached some photos. Where would I find these status lights you mentioned?
How do I tell what type of motor. I'm running 220v into a three phase converter.
ben
ID:	36615   Click image for larger version
Old 05-01-2007, 04:29 PM
Photos
Al, here's some more photos of my machine. hope they help.
ben
ID:	36617   Click image for larger version
ID:	36618   Click image for larger version
Old 05-01-2007, 05:27 PM
Al_The_Man's Avatar
According to the web site they have fairly sophisticated drives, I would get the model number and email them to see if they have the manual for your model.
http://www.contraves-drives.com/digidrve.html
I would be suprised if they do not have on-board diagnostic via the display etc.
Nice clean looking machine BTW.
Old 05-01-2007, 05:51 PM
Contraves manual
Al,
I have the Contraves operating manual. there's several sections:
1.Optional function: "speed-dependent limit current"
2.Maximum armature voltage, max. RPM
3.Speed Control action
Were do you think I should start????
Thanks for the comment on the machine.
Ben
Old 05-01-2007, 06:28 PM
gridley51 is on a distinguished road
I replied to a similar question on another board and the op did not respond.Is this the same question?
Is any of the red leds ajacent to the row of blue pots lit when the spindle stops?Which ones?Is there any leds lit on the field card which is the top one in your pic?
Mark.
Old 05-01-2007, 07:25 PM
Power check
Mark.
Mark, As my luck goes I powered up my machine after being off for about 5 hrs and ran two complete program runs without it stopping. concerning the leds=
led #208 (furtherest to the left) was lit
led #107 (next one to right) was off
led # 528 ( next to right) was off
then on the other side of the 6 pins (no jumper hooked from any pins)
led#D320- on
led#d21 -off
led#211-on
If my menory serves me right the only led lit when the spindle stops is D320, but not 100% sure. will run some more programs tommorrow and if it shuts down I check the lights and re-post to this thread.
thanks for the help.
ben
Old 05-02-2007, 07:42 AM
Question contraves board problem-Help
I've been having spindle shutdown problems for some time now on a intermittent bases. Noticed this morning that I had a burned out capacitor located on the contraves Supply pcb CPI board. Looks like a capacitor (see photo attached) I've been doing electronics work for 25 yrs and that's what it looks like to me. I've attached photos of the J54 jumper section on the board, photo of larger section of controller and even some drawings I have in the manual. I can't seem to find any reference to the capacitor that was across the last set of jumpers on J54. Sooooooooo I'm looking for someone that may have this contraves and can tell me the size of this capacitor.
Thanks,
May also try and email contraves in Germany to see if they can offer some advice.
Ben
ID:	36653   Click image for larger version
ID:	36654   Click image for larger version
ID:	36655   Click image for larger version
Old 05-02-2007, 09:21 AM
kreutz is on a distinguished road
It looks like a Varistor to me. The one on the left should be another one. You can get the information from that one.
Old 05-02-2007, 09:33 AM
Al_The_Man's Avatar
I agree it looks like a Varistor (MOV) also the sheet shows it as a snubber network, probabally works in conjunction with the Caps along side.
Unless it is shorted, I would not expect it to cause any problems like shutting down as it probabally only comes in to play when spikes appear, you probabally had a good one in the recent past that took the MOV out.
But it should be replaced. Clean the board up and check all the other snubber component if possible.
You should be able to get an equivalent replacement from DigiKey or any of the electronic supply houses.
  #12   Ban this user!
Old 05-02-2007, 09:43 AM
varistor
In the first graphic are you referring to the red circular one just above the far left X ?
ben
how do you orient spindle in program (fanuc 18m) rubino2112 Fanuc 2 01-24-2007 11:56 AM
Drive shutting down Halfnutz Stepper Motors and Drives 19 01-15-2007 05:42 PM
shutting down door alarm for mazak t plus scott 54 Mazak, Mitsubishi, Mazatrol 0 12-13-2006 07:27 PM
Camsoft CNC Pro- Computer Shutting Down mzartop6 CamSoft Products 7 05-08-2006 12:08 PM
Shutting down befor part is finished? Ken_Shea Haas Mills 9 07-31-2003 11:18 PM
