Old 04-22-2007, 01:30 PM
servocontroller is on a distinguished road
Question for Heidenhain Expert !!!
I want to drip feed Heidenhain. I am able to receive the program from my heidenhain control which is attached. The problem here is when i try to drip feed this program back to the machine it giives error "program format incorrect".
The problem i think here is with the End of Block character i.e * . It is visible
at the end of every block on machine monitor but the program received does not
have this * at the end of any block.
Is there any problem with the machine parameter for end of block character.
File Type: txt 230E2.txt‎ (239 Bytes, 67 views)
Old 04-22-2007, 05:32 PM
gus gus is offline
gus is on a distinguished road
Re
I am unfamiliar with the format for g code programs, but my first guess is ascii setup. You need to spec how many cr and lf are used somewhere, odds are you have an extra one or are short one. somewhere there is ascii setup in your transfer program
Other than that, if it faols to send even one line, is hte first character and that stuff correct?
Old 04-22-2007, 06:13 PM
bherr is on a distinguished road
Servo,
Don't know if you got an answer yet, but I looked in my Heidenhain book and here's what I found concerning data transfer. Why the program codes exceed the memory of the controller you can send data in the "Tansfer blockwise" mode. You start the transfer of data from the external storage in "single block" and "Full sequence" modes by pressing the EXT with the diamond around it. The TNC loads the program blocks in available memory and interrupts data transfer when memory capacity is reached. No program blocks are displayed on the screen until available memory is full or the program has been completely transfered. Although program blocks are not displayed, program execution can be started by pressing the external start button.. hope this helps.
Ben
Old 04-22-2007, 07:00 PM
tebisuser is on a distinguished road
%230G71
N10G30G17X-30Y-30Z-10
N15G31G90X+30Y+30Z+25
N20T1G17S850
N30G99T1L+18R+4
N40G00G40G90X+0Y+20Z+5M13
N50G01Z-6F50
N60G00Z+5
N70G00X+17.32Y-10
N80G01Z-6F50
N90G00Z+5
N100G00X-17.32Y-10
N110G01Z-6F50
N120G00Z+25M02
%230G71
the end
Stupid Heidenhain question of the day... swarf_rat Bridgeport and Hardinge Mills 12 04-08-2007 12:55 AM
Looking For An Expert! chipslinger Daewoo/Doosan 3 11-18-2006 01:41 PM
Heidenhain TNC 155 Control Question riggsmachine Bridgeport and Hardinge Mills 3 04-22-2006 05:38 PM
VMC 1000/20 with heidenhain tnc2500b controller question fatass CNC Machining Centers 1 01-13-2006 10:04 PM
Beginner question in Expert and 2d HuFlungDung OneCNC 22 07-13-2003 03:16 PM
