Old 04-21-2007, 11:11 PM
Daninwyoming is on a distinguished road
Question tacho loss -LED 11
I have an Interact 4 that I am getting a spindle drive fault. For a time I could reset the controller (Heidenhain 2500) and get the machine to restart. Then I began to have to push the reset on the FAC-IR board to restart. Then the spindle would come on and reach RPM and then coast to a stop. Now all I can get is the spindle drive fault on the controller and the tacho loss LED 11 on the Fac-IR board. Sometimes I also get the inst trip on LED 12. Today we checked the 4 brushes and cleaned the tacho on the spindle drive motor and switched out the FAC-IR board. I understand that the tacho DC voltage on the FAC-IR board should be 120 volts on terminals 6 & 8, But how do you check that? Is that at 4000 RPM? Any help out there?
Show us your tacho? chola General Electronics Discussion 0 02-07-2007 09:40 PM
Cancelled due to loss of enthusiasm. widgitmaster DIY-CNC Router Table Machines 16 11-08-2006 07:50 AM
How fast before step loss creep_pea Bridgeport and Hardinge Mills 8 01-05-2006 07:13 PM
Axis Loss Detection (Gecko) bill south Gecko Drives 1 11-04-2005 08:00 AM
easy tacho or encoder: cny70 reflective optical sensor gcamlibel General Electronics Discussion 0 10-12-2004 02:38 PM
