Old 04-19-2007, 03:00 PM
PRIOR666 is on a distinguished road
the servo don't standstill
hello i have one cnc miller bdp interact1 mk2 with tnc151 control, its was working fine but suddenly the servomotor for the axis x can't standstill when reference ande the control send me "gross position error d", i change the cables from the drive to motors and i think that trouble is the drive i follow the manual instructions for calibration for the drive but i cant't to stabilize.
any suggestions?
thank you.
Old 04-19-2007, 03:26 PM
mxtras's Avatar
Silver Member
mxtras is on a distinguished road
Reduce your gain.
Scott
Consistency is a good thing....unless you're consistently an idiot.
Old 04-19-2007, 04:04 PM
thank you
thank you for the answer scott, but i try with the gain tach pot and the motor vibration diminishes but still exist i copy the values to calibration for the other axis and it applies them in x, but nothing
Old 04-19-2007, 06:21 PM
Moderator
machintek is on a distinguished road
Any time I see an oscillation of an axis motor it has been a bad tach loop. This may be the tach on the motor, connectors, cable, or axis drive.
George
Old 04-20-2007, 09:48 AM
thank you for the advice
thank you machintek, today i will continue making test on this points i still very confuse, i still thinking that the problem is the drive card.
Old 04-20-2007, 10:36 AM
kreutz is on a distinguished road
any suggestions?
thank you.
If you connected any other axis motor to that drive, tested, and the problem is still there => it is the drive.
Old 04-20-2007, 01:13 PM
thank you kreutz
thank you for the suggestion, that test already made it and the problem moved at other axis so i think the drive is the problem, now i need to know if the drive can still be calibrate or if its damaged.
Old 04-20-2007, 06:46 PM
I don't think it is a calibration issue, you can probably contact the manufacturer for guidance. It seems like an encoder interface problem.
Old 04-21-2007, 10:31 AM
the problem is...
thank you, the problem is i dont know if the companie still support them.
Old 04-21-2007, 11:31 AM
Al_The_Man's Avatar
Are they the older Westamp drives? like these http://cnczone.com/forums/showthread...hlight=westamp
I usually replace these with modern AMC versions.
  #11   Ban this user!
Old 04-21-2007, 12:07 PM
It is a BOSCH
Thank you Al_The _Man, but my drive is BOSCH D-6120 you have any information for this drive? attach a photo of my drive
thank you
  #12   Ban this user!
Old 04-21-2007, 03:09 PM
gus gus is offline
gus is on a distinguished road
If you determine it is actually the drive, I have some tested good spares. Wil have to check the numbers, but look the same. Check what they cost to repair, I'm sure I'll sell one cheaper
Servo drive / Servo Amplifier Ken_Shea Servo Motors and Drives 9 07-10-2007 05:12 PM
pm feild servo servo eloid Servo Motors and Drives 4 03-03-2007 04:27 PM
