Old 04-18-2007, 07:58 PM
bherr is on a distinguished road
Question memory space in Series II interact 4?
I have a Bridgeport Series II Interact 4 with heidenhain 155b controller and I'm looking at doing engraving. Noticed that these programs run around 8,000 lines of code. what is the memory capacity of the TNC155b? I think I remember reading somewhere around 3000, but not sure.
Help please.
ben
Old 04-19-2007, 02:36 AM
awemawson is on a distinguished road
I believe that it is 3100 blocks, however if you are engraving with output from an engraving program you will easily outstrip that. You need to be drip feeding the control via the RS232 port
Andrew Mawson
East Sussex, UK
Bridgeport Series 2 Interact 2 Heidenhain TNC 155 rrossey Bridgeport and Hardinge Mills 9 05-16-2011 08:29 AM
series 1 nc, memory corrupted? tpretto Bridgeport and Hardinge Mills 8 10-04-2006 08:31 AM
Series 2 Interact 4 Retrofit UKRobotics Bridgeport and Hardinge Mills 1 05-14-2006 06:36 AM
Paper space Model space ?? CNCadmin Autodesk Software (Autocad, Inventor etc) 10 05-29-2003 06:07 AM
