Hi, First poster from the UK here, hoping to get help with our Heidenhain unit on our Bridgeport Series 1 Interact mill. The monitor's display is very feint now, and increasing the brightness using the knob on the front of the monitor panel hasn't improved things much. I understand the cost of a new monitor is astronomical, in the order of £1500 GBP. We've had a look at the graphics port's pin-out diagram and it doesn't appear to be possible to make an adaptor to allow us to use a normal PC's VGA (15-pin 3 row) monitor lead plug, and rest it on the shelf instead of using the embedded monitor (which uses 15-pin 2 row plug). Any advice welcome, whether it be compatible monochrome monitors with details so I can trace one on ebay, or adaptor possibilities to get a normal PC monitor working with it. Thanks, Phil. |
the early non graphics monitors don't cross directly to anything, but if you make and apapter , it is an inverted monochrome hercules or mga monitor. One could make a small circuit to invert the video[it comes out dark letters bright background with the retrace visible] Problem then is finding the monitor, as the refresh is too slow for any modern vga |
| Almost certainly the dim screen is just an low emission cathode on the CRT. If you can get any part numbers on the CRT then you could maybe source a replacement tube. AWEM
__________________ Andrew Mawson East Sussex, UK |
| Hi Mark, Yes, please could you send me details of this supplier. It would also help us if there are more problems with the unit in future. Thanks, Phil. |
| just remembered that I bookmarked this: http://www.dynamicdisplay.com/150800...ement_lcd.html I believe it synchs low enough to run on the heidenhain Dunno price |
| Looking into Gus' link, here is another at the same company: http://www.dynamicdisplay.com/qes900..._monitors.html the QES914-112 is Hercules video and even has the amber phosphor for that authentic look..... |
#10
| Thanks guys, I'm currently on the trail Mark/gridley51 put me on, which is to buy a recon'd monitor from a reputable company here in the UK. I'll post my findings here when I get the replacement monitor. gus/swarf rat - As usual, us UK'ers look across the pond with envy at the prices you get to pay! It might be cheaper than a replacement OE monitor bought here, but the recon'd monitor looks to be about £700, which is about half price of a new OE unit like gus said. |
#11
#12
| can anyone help with heidenhain 2500 control parameters? | greg b | Bridgeport and Hardinge Mills | 14 | 02-21-2012 07:43 AM |
| Heidenhain tnc 2500 on Interact 308 | GarageShop | Bridgeport and Hardinge Mills | 16 | 12-15-2010 04:57 PM |
| Heidenhain 2500 parameters | Daninwyoming | Bridgeport and Hardinge Mills | 17 | 06-10-2010 12:35 AM |
| Heidenhain TNC 2500 in Interact 308 | GarageShop | Bridgeport and Hardinge Mills | 12 | 08-24-2008 04:16 PM |
| Heidenhain 2500 - Programming Z Axis | palikalsi | General CNC (Mill and Lathe) Control Software (NC) | 0 | 03-26-2007 08:46 AM |
