Old 04-12-2007, 09:02 AM
Jonne is on a distinguished road
What do BP S1 CNC ACC-board?
What is ACC-boards purpose?
How I can test it? ( I read somewhere,
flipping board on connector, x and z change place. But I don' mean that,
some ratings or behaviour of board will be nice. )
And last question: Where I can measure stepper amps? Fuseholder No. ?
Johannes
Old 04-12-2007, 11:03 AM
servocontroller is on a distinguished road
Acc board is used to control the DC voltage input of the saturable core reactor which in turn controls the large current flowing to the motor under normal conditions (not sure) approx 8 amp of current is flowing in the steppers in order to maintain their position.
You can measure the current using clamp Meter.
My BP series 1 is not having one reactor So in the near time I am going to study thorougly the signal from ACC board and the response of the reactor.
i am thinking of replacing reactors with Triacs.
Old 04-12-2007, 03:57 PM
keebler303 is on a distinguished road
the above is correct. The current can be measured by removing fuse 12,13,14 which correspond to x,y,z and inserting an ammeter across the terminals. The potentiometers on the ACC board are used to adjust the current. It should be around 8-8.2 amps. Make sure not to disconnect anything while the machine is on, bad things may happen.
Matt
Old 04-13-2007, 08:02 AM
I just want to get rid of these reactors is it possible?
because advance axis drives use mosfets instead of transistors and opamps for current limiting
Old 04-15-2007, 04:35 AM
Thanks everyone, machine working right now, only that one of
smd board is faulty...
Breakout board, Relays on board? Cooper Open Source Controller Boards 11 06-09-2007 07:55 PM
Can I hook up a 3-axis board to a 1-axis board ? Redline Xylotex 7 02-09-2007 09:45 PM
new to board bruno123 Xylotex 0 12-21-2006 03:23 PM
HDU board maxxgraphix WoodWorking 6 03-30-2005 05:47 AM
