Old 04-12-2007, 06:50 AM
MrHorsepower is on a distinguished road
Question Boss 5 Conversion Has A Transformer And Vfd ???
I am in the middle of the conversion on my Boss 5 and have decided to use a KEB inverter drive with the stock motor to power my spindle. My drive will accept single phase input which would allow me to run without a phase converter. My question is-is there any way to wire my three phase main power (60V) on single phase power other than just using only 2 legs. I suspect there is a simnple solution but I just haven't had the "vision" yet. Also while we are on this subject; Do I scrap the whole vriable speed pulley and and belt assy? Or use it and set it to a cetain spot and "lock" it in? I assume that I will want to keep my high and lo range in any case. Looking for any and all opinions. Thanks in advance.
Old 04-12-2007, 09:19 AM
wyobmf is on a distinguished road
I VFD'd my series II. My belt and pulley and speed change all worked so I just run my VFD at 60 Hz and vary the speed with the original speed change. You just need to put 24 VDC to the speed change switch and find the wires for your soliod valves. What is: three phase main power (60V)?
Old 04-16-2007, 07:59 PM
What are you using the VFD for? I am talking about the Main power transformer (60V). And a series 1 doesn't have solenoids for "speed change" it has a lever.
Old 04-17-2007, 07:42 AM
Yes there is a simple solution. Mach 3, a breakout board, gecko drives and a new power supply.
I was not aware on how SI change speed, just giving you an example on how I did mine.
Old 04-17-2007, 02:13 PM
I am doing Mach, Gecko's, and an NCPod. I would like to use PWM out of the pod to control speed through my new Inverter. I am constructing a new power supply, using my old (60V) 3 Phase main transformer. I am ditching the saturable reactors and running unregulated. This should fall withing the Gecko ripple allowance. I would be ok to run on 2 pahase of transformer but would like to wire all 3 some how. Is that clearer?
Old 04-17-2007, 02:37 PM
Clear as mud,
Why not just buy a new XFMR?
Old 04-17-2007, 06:06 PM
Gold Member
HillBilly is on a distinguished road
Here is a thread on the transformer.
http://www.cnczone.com/forums/showthread.php?t=21866
Darek
Old 04-17-2007, 09:07 PM
Always Forget About The Search!! Thanks!
Bridgeport BOSS 5 Conversion Complete tpres500 Bridgeport and Hardinge Mills 0 02-25-2007 11:12 PM
BOSS 6 T2 transformer Hood Bridgeport and Hardinge Mills 9 11-28-2006 04:52 PM
Boss 8 to Mach Conversion Help TurboStew Bridgeport and Hardinge Mills 4 10-26-2006 08:44 PM
220 to 440 transformer conversion Rich Carlstedt General Electronics Discussion 1 09-14-2006 07:42 AM
Value of series 1 BOSS w/working modern CNC conversion? SRT Mike Bridgeport and Hardinge Mills 0 12-10-2005 10:47 PM
