I have been working on interfacing my TNC for more than a month. I am new to heidenhain so please don't mind if i go wrong. 1. using "ext" mode and cable with wiring shown: <DB9>(PC)-------------------<DB25>(TNC 155) 2 <---------------------- > 2 3 <----------------------> 3 5 <----------------------> 7 1,4,6 looped ------------------8,20,6 looped 7,8 looped-------------------4,5 looped and using a DNC software I can receive any G code(already present) from my TNC at my PC but i am unable to send my G codes blockwise to the TNC.I have attached the G codes i received from my TNC. A point to be noted is there is no end of block "*" and no file type of it. at the end of received G codes this * is visible on the machine. 2. I downloaded TNCremo for win98 and when i run it in win98 it gives error before the setup begins i.e "The specified service already exists". 3. According to the discussion going on the forum i tried to connect the machine in FE mode using Pro NC evaluation version (as i failed with TNCremo)and the wiring diagram given by "awemawson" but again no response. It gives error the "End of Block missing". when i use MP223 = 1 p I am unable even to connect in "ext" mode. 4. what are the parameters required for using G codes and transfer blockwise. servocontroller |
| Attached is a tech bulletin from Bridgeport for TNC communication. And a cheat sheet for using PROCOMM with a TNC2500, and a DOS program used with an old RAdio Shack TRS-80 Model 100. George
| please tell me which controller on ur machine? tnc151/155 can use bolck wise i have full setting of tnc155/151 for block wise moghul40@yahoo.com |
| Heidenhain, Bridgeport TNC150 problems! | mossy | Machine Problems, Solutions , Wireless DNC, serial port | 4 | 10-01-2008 01:08 PM |
| Interact with Heidenhain TNC155B RS232 Interface | rrbmachining | Bridgeport and Hardinge Mills | 16 | 04-10-2007 09:20 AM |
| Heidenhain programming problems | lt1pat | General CNC (Mill and Lathe) Control Software (NC) | 1 | 03-12-2006 10:28 AM |
| My new interface... | murphy625 | CamSoft Products | 5 | 04-15-2005 05:27 PM |
| pc to driver interface | wired | General Electronics Discussion | 3 | 01-06-2005 06:52 PM |
