Old 03-25-2004, 08:35 AM
inthedark's Avatar
inthedark is on a distinguished road
How To; troubleshoot an Axis problem on Bridgeport BOSS
Bridgeport BOSS troubleshooting for Axis not moving
“This procedure to be done if you are having problem with 1 Axis”
1. These fuses can be shorted to a point where the give high readings. Check to be sure the voltage is about 8-9 volts. Swap Axis fuses (both) and test for movement. If it moves, you have a bad fuse. Fuses should read 0.5 ohms -+ a bit.
2. You can swap the SMD cards to test for a bad SMD card. If you swap cards, and the problem moves to another Axis, you have generally found a bad transistor on that board. Component level testing would be required now.
3. You can also flip the ACC board, the electronics are
reversible. If you swap cards, and the problem moves to another Axis, you have found a bad power transistor. Component level testing would be required now.
"Plan your work; Work your plan"
DNC with parallel port (Bridgeport BOSS 5)? hobbymat General CAM Discussion 3 07-20-2009 12:16 PM
Series 2 BOSS 6 Axis motion problem craig96us Bridgeport and Hardinge Mills 43 01-14-2006 12:06 PM
Need so Bridgeport Boss education. AAA Bridgeport and Hardinge Mills 10 08-01-2005 08:39 PM
Bridgeport EZ Track TLO problem Alan k Bridgeport and Hardinge Mills 9 05-26-2005 05:56 PM
Fadal VMC4020A axis problem cwww Machine Problems, Solutions , Wireless DNC, serial port 16 12-02-2003 12:07 AM
