Old 03-28-2007, 07:30 PM
smirob is on a distinguished road
Interact 412 error
Hello all,
I've recently purchased a Bridgeport Interact 412. I'm getting an error when I start it up that says:
Axis PSU Fault
I'm not sure what its reffering to, nor can I pinpoint the problem. I assumed it may be a power supply issue, so I switched my Pole 1 and Pole 3 on my 3 Phase power.
If someone has seen this error, or has an idea as to what it may be, I would appreciate it. I can't home any of the axes with this error on screen, nor can I just clear it.
Thanks,
Rob
Old 03-29-2007, 05:11 PM
Moderator
machintek is on a distinguished road
This machine came with a Heidehain control or a Fanuc. Also the insides of the machine varied. You need to be more specific.
A axis Power Supply Alarm is a bit odd as if it has the Bosch axis drives, there was no power supply for them. It received power from a transformer. Maybe you have some blown fuses or the power to the machine is wrong.
George
Old 03-29-2007, 09:59 PM
Thanks for the reply machintek. I've just spent 5 hours tonight on it and progress was made. Here's what I've found out.
I never checked the 3 phase going into the master breaker, and one leg had become unattached, and the others were loose. After addressing that, I was able to get the machine up and going.
As far as the servo drives go, the original Bosch's went out, so the prior owner replaces all 3 with Advanced Motion Drives. Also, the Fanuc drive went out, so he replaced with a Mitsubishi VFD A-200. He did say, that that VFD wouldn't work with my tool changer without the optional input board. He also said that he thought that the X axis board went out, so he swapped the cable to the A axis board and swapped them at the control as well. BTW, its a Heidenhain control. He said that the X axis wouldn't home, but he was still able to cut parts. That said, I do have 2 issues I'd like to ask about.
1) When I try to move the x axis, whether by manual jog, or in running a program, the x axis jogs back and forth, almost like its hunting for position. The Y and Z move just fine. I'm wondering if a loose ground or other wire are possibly loose?
2) Where can I find this accessory board for my VFD, so I can use the ATC? If it's too much of a chore, then where can I find the Fanuc OM control to run the spindle, as the tool changer is important to me.
3) I haven't been able to reach by telephone the fella' I bought this from, but I'm not sure how he entered spindle control from the heidenhain console. I can physically go to the VFD and turn it on, and it will run, but I don't know how to adjust the rpm's either at the VFD or at the control. It's puzzling, because 2 BT40 tapping heads came as part of the tooling I got from him. It makes me believe that I'm overlooking some way to control the Spindle fwd/rev or rpm's.
I apologize for my ignorance on these subjects, its just this is very new for me to delve into. Any helpful advice, would be greatly appreciated.
Thanks in Advance,
Rob
Old 03-30-2007, 08:53 AM
gus gus is offline
gus is on a distinguished road
re
Wow, what a nightmare.
x axis sounds like it needs the tach feedback adjusted in a big way. The PO sounds ummm, technically, umm, challenged. Drives aren't that flakey, why did the boschs die, then an AMC?
Download manual for the drive if yo don't have one, and tweek the drive, sounds like it is sending out way to high a signal for a given speed then trying to back up, which it thinks it is doing too fast etc, etc loop.
Spindle speed is set in the tool call, on and off should be m3/m5
Old 03-30-2007, 10:23 AM
Interact 412 error
Well as far as I know, when I picked up the machine, I asked why he replaced all 3 bosch drives, he said "one went out and it was $500 for a single from England, so I got 3 advanced motion drives for $340". I have given it an m3 and m5 for spindle calls, both in MDI and with a program that was already in the control. When it gets to that line, it doesn't do anything when it sees the command.
Thanks again,
Rob
PS-Yes, the prior owner was a real "winner". The machine does not look like it was well kept, however, the ways are good, and there is potential. And for $1300 I'm hoping I've found a diamond in the rough. I'm not opposed to spending some money to get it back to working condition. I just have to draw a line as to when it gets to be too much money, do I retrofit the control with Mach, Ajax or something else.
Old 03-30-2007, 11:24 AM
Moderator
Typically, as stated, a servo motor with a velocity loop (tach) will yo-yo when this loop goes open. It will oscillate back and forth.
The spindle speed is defined with the tool? I am trying to remember. Then a M function is called up to turn it on. But are you using conversational or G&M code with the special G&M code keypad? I have not run one since 1987. But since this is a non-standard set up (Frankenstein), all bets are off as to what signals are connected.
The tapping heads may be from when the OEM guts were inside the machine.
George
Old 03-30-2007, 01:08 PM
gus gus is offline
ok, which heidenhain?
the m3 starts the spindle, the tool call will set the speed, if there is no speed set, it is running, but at 0 rpm.
22 TOOL CALL 0 Z S 2000
23 L X+2,000 Y-1,3100 R0 F2000 M03
24 Z+0,1000 R0 F2000 M
this sequence is right out of a program, should set a spindle speed, and start it rotating. If you can't move the axis change them to IX0 IY0 etc
If the machine is emo'd the spindle won't run......
Old 03-30-2007, 01:11 PM
gus gus is offline
BTW, this is probably not a control problem, so you are MUCH better off trying to make it run right as it is, then see if the control has shortcomings that need a retrofit. I don't think any aftermarket control can do anything this one can't, but like many older controls, memory is somewhat limited
Old 03-30-2007, 07:34 PM
Thank you for the input thus far.
So, I had someone who is much more familiar with these things than I come look at it. He determined that the X axis encoder bulb was going bad. He removed the unit and is going to attempt soldering a replacement. He said it is very tedious work, and I should look on the internet for a backup in case all does not go well. So I took a picture of the encoder cap and it says its an ERO 115 200, Id. 217 900 10.
Here's a picture of the light unit mounted inside the cap.
http://s178.photobucket.com/albums/w...t=IMG_1542.jpg
Here's a picture of the encoder endcap.
http://s178.photobucket.com/albums/w...t=IMG_1548.jpg
So, if anyone knows of where I can buy the light setup or, if necessary the entire encoder, I would appreciate the help.
My buddy also suggested I try to get the orginal Fanuc OM from the prior owner, so I was able to finally contact him and he said he pulled it because the top board burn up. He said the other board in there was worth $150, so that's what he wants for the junk Fanuc. I'm hesitant to drive back to his place (4 hours one way), but I'm willing to spend some money to get this machine back to what I should be. I'm just wondering how much a good used Fanuc or new Fanuc costs.
Thanks again for all the help,
Rob, MI
Old 03-30-2007, 07:36 PM
OOPS! I forgot to mention. This is an Heidenhain 151 control.
Old 03-30-2007, 08:53 PM
Al_The_Man's Avatar
The board you want for the VFD to orient the spindle is a FR-EPA Option, you can get it from MEAU in Chicago, but it may be hard to get and/or expensive as this is now a legacy drive.
The VFD has to be in External Run to accept external commands, if you are commanding it from the keypad, then it is in local mode.
I have installed a few of these using the analogue signal and M codes to control.
I have the manuals for this drive, including the Training Manual in PDF.
The MEAU site is also a source of them, I believe.
  #12   Ban this user!
Old 03-30-2007, 11:14 PM
Any idea of the cost for the add-on board? Obviously, because its the weekend, I'm SOL right now.
I too have the Manuals and Training Manual for this drive. Much of it reads like Greek to me, but I'm hoping it will help anyone I can corner for assistance with the machine.
I'm assuming when you made mention of Analog setup that this is included in that realm. Also, I got to thinking abou the breaking or stopping of the spindle for a tool change and holding it into place. How would that happen?
Regards,
Rob
tl-2 program integrity error and program data error alarm #'s 212 250 need help CNChelp Haas Mills 12 03-14-2010 08:19 PM
Interact 412 code Bridgeport and Hardinge Mills 3 02-01-2008 08:36 PM
Help with a Interact I mk 2 pjeran Bridgeport and Hardinge Mills 16 03-17-2007 10:53 AM
Interact 412 besc Bridgeport and Hardinge Mills 0 08-24-2006 07:52 AM
Help with Interact 1 Mk 2 Please! Alfonzo Bridgeport and Hardinge Mills 6 02-03-2006 03:33 AM
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471 472 473 474 475 476 477 478 479 480 481 482 483 484 485 486 487 488 489 490 491 492 493 494 495 496 497 498 499 500 501 502 503 504 505 506 507 508 509 510 511 512 513 514 515 516 517 518 519 520 521 522 523 524 525 526 527 528 529 530 531 532 533 534 535 536 537 538 539 540 541 542 543 544 545 546 547 548 549 550 551 552 553 554 555 556 557 558 559 560 561 562 563 564 565 566 567 568 569 570 571 572 573 574 575 576 577 578 579 580 581 582 583 584 585 586 587 588 589 590 591 592 593 594 595 596 597 598 599 600 601 602 603 604 605 606 607 608 609 610 611 612 613 614 615 616 617 618 619 620 621 622 623 624 625 626 627 628 629 630 631 632 633 634 635 636 637 638 639 640 641 642 643 644 645 646 647 648 649 650 651 652 653 654 655 656 657 658 659 660 661 662 663 664 665 666 667 668 669 670 671 672 673 674 675 676 677 678 679 680 681 682 683 684 685 686 687 688 689 690 691 692 693 694 695 696 697 698 699 700 701 702 703 704 705 706 707 708 709 710
