Old 03-23-2007, 10:00 AM
rrbmachining's Avatar
rrbmachining is on a distinguished road
Interact with Heidenhain TNC155B RS232 Interface
I am having trouble getting the link set up between my PC running TNCremoNT and my TNC155B controller. Im certain the pc end is ok but am unsure what lead to use, the pc has a 9 pin din and the TNC is a 25 pin. Should i be using a lead for software or hardware handshake ?
Also i am not sure if the controller is set up correctly to see the peripheral device
Any help would be much appreciated
richard
rrbmachining@yahoo.co.uk
Old 03-23-2007, 11:15 AM
gus gus is offline
gus is on a distinguished road
re
first you have to tell us what error you are getting
to convert to the 9 pin you need to jump two pins and I don't hve that in front of me. The tnc wants to see the handshaking, so is it cts and rts, I think lookin a the diagram on the other thread, pins 4 and 5 on the 25 pin are jumped together, then 2 and 3 are crossed. My old 145 wanted 7 bits, 1 stop bit even parity but I think that is changeable on other controls
Old 03-23-2007, 12:27 PM
awemawson is on a distinguished road
richard
If you go back there is a recent thread where I put in the specific cable wiring for this.
AWEM
Andrew Mawson
East Sussex, UK
Old 03-23-2007, 12:31 PM
Here you go::::::
Download TNC REMO from Heidenhain's site - set it up and run TNCSERVER
Make up a cable from 25way TNC151B to 9 way PC as follows:
(25way TNC) <9 way PC>
(2) - <2>
(3) - <3>
(4) - <8>
(5) - <7>
(6) - <4>
(7) - <5>
(20) - <6>
The TNC RS232 interface can exist in three modes - "EXT", "ME", and "FE" selected via the 'MOD' key - it should be in "FE"
File names & extensions ARE important in block mode transmission. 123.H = program 123 in Heidenhain conversational code and 123.I is program 123 in ISO-Gcode
When set up like the above it will work - it took me ages to sort it but now all is reliable.
Andrew Mawson
East Sussex, UK
Old 03-24-2007, 03:50 AM
Thanks for all the replies, I will give it another try today
With regard to the last reply from awemawson, shouldn't pins 2 and 3 get transposed in the cable ?. I found that diagram after a lot of searching on page 3-5 of the Heidenhain data interface manual, however there appears to be a discrepency between the two drawings
richard
Old 03-24-2007, 04:30 AM
richard
No that's the way 9 and 25 way do it !
Pin 2 is transmit data on 25 pin and received data on a 9 pin
Pin 3 is received data on a 25 pin and transmit data on a 9 pin
Look at Pin Assignments here :
http://www.camiresearch.com/Data_Com...#anchor1155222
AWEM
Andrew Mawson
East Sussex, UK
Old 03-24-2007, 04:59 AM
thanks for that andrew, that could explain alot, i will give it a try later for sure
richard
Old 03-24-2007, 01:56 PM
Well im making some proress thanks to all the help i have had, the TNC now seems to talk to the pc running tncserver as the link goes active when i try to transfer a file, however the file does not appear on the pc so i guess the transfer is not complete or corrupt, from what i can see the settings match at the tnc and the pc, anymore thoughts anyone ?
richard
Old 03-25-2007, 04:59 AM
richard
TNC server should say 'awaiting request' when it has seen a valid RS232 connection, otherwise it will say 'no connection' Does TNC server start counting up blocks as the transfer starts? Have you set up the folder option on TNCserver to tell it where to put the file?
AWEM
Andrew Mawson
East Sussex, UK
Old 03-25-2007, 05:23 AM
TNC server does say awiting request, the server does have a folder defined but when i try to transfer a file the status goes active for about 5 seconds and nothing happens in the bottom 4 fields of the server window. Maybe its something to do with the file name or extension but as yet i have not worked out how to check this
richard
  #11   Ban this user!
Old 03-25-2007, 06:13 AM
richard
You do have the TNC155 in 'FE' mode and the TNCserver in FE/ME mode don't you? What happens if you try to upload a file? (if in conversational mode the file must be a number with an .H extension and if in Iso mode a number with a .I extension ie 300.H or 300.I - I don't think you can use anything other than numbers for file names, but the number doesn't have to correspond with the program number embeded in the code iirc
AWEM
Andrew Mawson
East Sussex, UK
  #12   Ban this user!
Old 03-25-2007, 12:46 PM
The TNC155 is in FE mode and the server software set to send/recieve FE. I cant try to upload as i have no files on the server
richard
Heidenhain tnc 2500 on Interact 308 GarageShop Bridgeport and Hardinge Mills 16 12-15-2010 04:57 PM
RS232 for Heidenhain TNC 151/Mastercam 8.1 Huntersyv Machine Problems, Solutions , Wireless DNC, serial port 8 12-11-2007 11:07 PM
Interact 1 Mk2 with Heidenhain TNC155B rrbmachining Bridgeport and Hardinge Mills 6 03-22-2007 01:18 PM
BobCad to Heidenhain TNC155b problem bherr Bridgeport and Hardinge Mills 0 01-13-2007 09:19 AM
Heidenhain TNC310 RS232 Al_The_Man Mazak, Mitsubishi, Mazatrol 5 04-27-2005 09:18 AM
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471 472 473 474 475 476 477 478 479 480 481 482 483 484 485 486 487 488 489 490 491 492 493 494 495 496 497 498 499 500 501 502 503 504 505 506 507 508 509 510 511 512 513 514 515 516 517 518 519 520 521 522 523 524 525 526 527 528 529 530 531 532 533 534 535 536 537 538 539 540 541 542 543 544 545 546 547 548 549 550 551 552 553 554 555 556 557 558 559 560 561 562 563 564 565 566 567 568 569 570 571 572 573 574 575 576 577 578 579 580 581 582 583 584 585 586 587 588 589 590 591 592 593 594 595 596 597 598 599 600 601 602 603 604 605 606 607 608 609 610 611 612 613 614 615 616 617 618 619 620 621 622 623 624 625 626 627 628 629 630 631 632 633 634 635 636 637 638 639 640 641 642 643 644 645 646 647 648 649 650 651 652 653 654 655 656 657 658 659 660 661 662 663 664 665 666 667 668 669 670 671 672 673 674 675 676 677 678 679 680 681 682 683 684 685 686 687 688 689 690 691 692 693 694 695 696 697 698 699 700 701 702 703 704 705 706 707 708 709 710
