Old 03-15-2007, 10:03 AM
jonny is on a distinguished road
BOSS 8 EMC boot sequence
EMC boot sequence
Turn off all four LEDs
Send two blanks (char20) to LCD
Turn on LED 3 only
Test LCD RAM
Turn on LED 4 only
Test rest of RAM (probably unused RAM only)
Turn on LEDs 3 & 4 only
Test A to D converter AD7581 (feedrate over ride)
Turn on LED 1 only
Test/configure timers 9513A
Turn on LED's 1 & 3 only
Test/configure inturrupt controllers 9519A
Establish stack
Clear RAM from EFD2 to FDD2
Clear tool table (probably skipped if conditions are met)
Start LED 2 blinking
Old 03-28-2007, 06:30 PM
Newby2 is on a distinguished road
jonny...I owe you a heaping bunch of thanks and a few cases of beer. I have been having problems with my R2E3 Boss 8 II and with your post, I was able to locate the problem! My machine would not boot beyond the A to D convertor test. LED's 3 and 4 were on, The display would show "WAIT" and the next line was showing "3"
I removed the AD7581 IC (IC25), cleaned the contacts, reinstalled and now everything is booting up and I am able to run the machine once again!
Again, have a whole bunch of beers on me!
Thankyou!
Steve
Old 04-02-2007, 10:00 PM
With the help of jonny's post, I found a bad IC on the mother board. I also located a supplier for this chip through American Microsemiconductor, Inc. (www.americanmicrosemi.com) in Madison, NJ. At $20 bucks apiece, it was a great relief to find that I did not have to spend $600 to $700 for a replacement board.
Steve
cut sequence camtd Surfcam 2 06-13-2006 12:26 PM
Sequence #'s Mountainwildman Post Processors for MC 2 04-02-2006 12:25 PM
Wire sequence? scratch_6057 Stepper Motors and Drives 3 03-30-2006 08:33 AM
Drilling - Tapping sequence sleepydog G-Code Programing 2 01-22-2006 11:36 PM
Power up sequence Konstantin General Electronics Discussion 1 10-05-2004 06:05 PM
