Old 03-12-2007, 07:30 PM
PRIOR666 is on a distinguished road
help with electronic handwheel of tnc151b
Hello to all
i can run my cnc miller (bridgeport mk2 with control tnc 151b) thanks to this forum, but still need one thing more, mi electronic handwheel can't work and apparently dont have any damage, i believe that there is a parameter 171 but already attempt with 0 and 1, which is the correct one? plus i dont know if its connected well, in my machine this connected one in a place different to the manual. i attach 2 photos.
somebody can help me
ID:	33464   Click image for larger version
Name:	handwheel manual.JPG‎
Old 03-13-2007, 10:47 AM
gus gus is offline
gus is on a distinguished road
re
Yours is also correct, although very different from my 151, I don't have that connector at all! Look in other places in the manual and you will see this connection style.
there are also 2 and 3 as options for that parameter
Old 03-13-2007, 12:10 PM
thank you for your reply Gus
thank you for your answer Gus, unfortunately my manual don't have more information and i don't know if my handwheel its connected well, one more question, what its the difference between the parameters to 171 (0,1,2,3)?
thank you and regards
Old 03-13-2007, 12:19 PM
gus gus is offline
re
download the full tech manual from heidenhain.com
I am not quite sure, perhaps machinetek knows , has to do with 2 different handwheels and two different something else, dunno what the something else is
shouldn't hurt anything by changing, just more not working
Old 03-13-2007, 12:39 PM
I will continue attempting
thank you Gus, i willl try to follow your suggestions.
Old 03-14-2007, 04:38 AM
awemawson is on a distinguished road
Parameter 171
There are four possible values for parameter 171 which select which hand wheel and touch probe system is connected:
0 = HR150 or HR250 and TS510
1 = HE310 and TS510
2 = HR150 or HR250 and TS110
3 = HE310 and TS110
TS110 is a cable connected touch probe
TS510 is optically connected to a remote unit that then is cable connected
So you need to decide which handwheel you have and select for it. I think the fact that the touch probe is not connected is irrelevent to this parameter
Andrew Mawson
East Sussex, UK
Old 03-14-2007, 12:21 PM
my handwheel don't respond
thank you awemawson, but i already attepmt all and nothing and begin to think that my handwheel its damage of something way, some form (parameter, button, etc) exist of something this blocking this handwheel?
thank you.
Backwards Handwheel on Centurion 6 TZ250 Milltronics 2 02-28-2007 11:01 PM
tm-1 handwheel removal? superrat Haas Mills 6 11-10-2006 10:52 AM
V2XT Handwheel encoder jrrhotrod Bridgeport and Hardinge Mills 3 05-11-2006 09:42 PM
Handwheel Installation plateroomred CamSoft Products 3 05-24-2005 05:28 PM
Camsoft Handwheel problems Ben Olson CamSoft Products 32 07-16-2004 10:17 PM
