Old 03-12-2007, 12:37 PM
Dar Dar is offline
Dar is on a distinguished road
Question bridgeport 2/heidenhain tnc145
ok guys i finally figured out a pocket program and ran it. except for the offset
it looked swell running. i decided to run it again just to watch it. this was the next day so power was interupted. when i turned it on and tried to home it . it showed [y limit switch] . the table is almost dead center on x and y. looked under at switch and checked with meter . switches are good. any ideas would be appreciated.
thanks Dar ps it seems like every time i get a chance to learn more about it something fails. this machine is 20 years old ,it was run for the first 5 and sat idle for the next 15.
Old 03-12-2007, 04:24 PM
gus gus is offline
gus is on a distinguished road
re
I am betting that the y axis trip dog is stuck engaged. There are two switches in one housing, one is the y axis + - overtravel and the other is the trip dog. The machine only looks at the trip dog while homing, so it is possible that it stuck down the last time you homed, and now it homed in the middle of the table.
non flashing limit errors are software limits, not hardware[switch]
take the switch housing off, it is on the right, currently hidden by the x axis motor, and clean out the plungers so they actuate smoothly.
Bridgeport heidenhain controller????? bherr Bridgeport and Hardinge Mills 4 05-23-2010 02:28 PM
bridgeport 2/heidenhain tnc145 Dar Bridgeport and Hardinge Mills 4 03-19-2007 09:05 PM
Looking for help for bridgeport/heidenhain 155 plane magic Bridgeport and Hardinge Mills 6 02-26-2007 08:00 PM
Need Heidenhain Tnc145 Post For Pro/e Wildfire ARIF AHMED Post Processor Files 0 10-16-2006 11:48 PM
Heidenhain TNC145 post zafarsalam Post Processors for MC 2 04-09-2006 09:26 PM
