Old 03-12-2007, 12:33 PM
Dar Dar is offline
Dar is on a distinguished road
bridgeport 2/heidenhain tnc145
ok guys i finally figured out a pocket program and ran it. except for the offset
it looked swell running. i decided to run it again just to watch it. this was the next day so power was interupted. when i turned it on and tried to home it . it showed [y limit switch] . the table is almost dead center on x and y. looked under at switch and checked with meter . switches are good. any ideas would be appreciated.
thanks Dar
Old 03-12-2007, 07:42 PM
Moderator
machintek is on a distinguished road
Yes, but is the 24 V getting back to the control?
George
Old 03-12-2007, 08:31 PM
Dar Dar is offline
Wink
well george i guess it was a false alarm. when i started it today it was fine???
thanks Dar
Old 03-13-2007, 10:33 AM
gus gus is offline
gus is on a distinguished road
moved from you other thread:
I am still betting on this, it would explain it perfectly. Be careful if this switch is dodgy, it can cause a minor crash
I am betting that the y axis trip dog is stuck engaged. There are two switches in one housing, one is the y axis + - overtravel and the other is the trip dog. The machine only looks at the trip dog while homing, so it is possible that it stuck down the last time you homed, and now it homed in the middle of the table.
non flashing limit errors are software limits, not hardware[switch]
take the switch housing off, it is on the right, currently hidden by the x axis motor, and clean out the plungers so they actuate smoothly.
Old 03-19-2007, 09:05 PM
Dar Dar is offline
thanks Gus it seems to be ok now but i,ll keep an eye on it
Dar
Bridgeport Interact 412/Heidenhain TNC 151 HELP? larrynsr Bridgeport and Hardinge Mills 15 08-30-2010 06:06 AM
Bridgeport Series 1 Heidenhain TNC 145 pestana1957 Bridgeport and Hardinge Mills 27 08-05-2009 06:13 PM
Looking for help for bridgeport/heidenhain 155 plane magic Bridgeport and Hardinge Mills 6 02-26-2007 08:00 PM
Need Heidenhain Tnc145 Post For Pro/e Wildfire ARIF AHMED Post Processor Files 0 10-16-2006 11:48 PM
Heidenhain TNC145 post zafarsalam Post Processors for MC 2 04-09-2006 09:26 PM
