  #13   Ban this user!
Old 03-15-2007, 12:10 AM
9 1/2's Avatar
9 1/2 is on a distinguished road
Thanks NC,
The vendor indicated this unit was all original including the rotary.
B.C.I.T. Machinist CNC
  #14   Ban this user!
Old 03-15-2007, 02:16 AM
v488 is on a distinguished road
NC Cams, great infomation! I'll check on my bearing #'s. I tossed the boxes. The bearings i'm running now came from Hardinge and i was told thay are the same parts thay are using in the new built Mills. My biggest upset is that i'm flat broke $$$ with the mill now. I have another set of bearings sealed in plastic bags. NSK DM177 7207C SUMP4 JAPAN D also NSK DM180 7207C SUMP4 JAPAN D #'s on box are 714072075 7207CD/P4DBA Boxes where taped together and says 1 pair. I'm sure these are Angular Contact. Are all angular contact bearings unsealed? Without re-inventing the wheel it would be HARD to get oil to unsealed bearings. On a V2XT there ia a Ball Screw bolted to the top of the quill and this blocks off any oil cup and drip set up. WELL as i'm typing and thinking, it could be possible to do! Could the unsealed bearings be greased, one time i made some delrin rings that pressed onto a spindle bearing spacer and set against the bearing to help hold grease in.
If the angular contact bearings are the way to go i would put the effort into the mill housing for oil. I've read many places that the DEEP GROOVE bearings don't make good spindle bearings.
I've got another b-port mill that was rebuilt in the early 90's and i bought it from the shop where i was working. It has angular contact bearing and theres never been a problem with it. I'm sure the rebuilder KNEW what he was doing!! I think it was somewere in RI. ? Thanks
  #15   Ban this user!
Old 03-15-2007, 04:15 PM
NC Cams is on a distinguished road
The 7207SUMP4's are 207 sized, single universal ground (mountable in single, DB or DF position) and a medium preload with P4 (ISO equivalent to ABEC 7).
These should give you great performance and accuracies in the lower spindle mounting position, espcially compared to the 11190238 OEM bearings that were in there if/when Bridgeport made the machine. These bearings were originally modified 6207's that were hybrid ABEC 3's in some areas and 7's in other areas.
If you use the 7207 NSK's, make sure the lower bearing spacers (12193513, inner and outer) are ground EXACTLY the same axial length as each other and the ends are ground perfectly parallel.
You could grease them with about a 25% or so fill and this should be fine. I suspect that the oil that is in the original reservoir actually provides lube to this lower bearing - the OEM bearings did not call out for a grease lubed hence the lube must have come from the spindle reservoir.
If the spindle bearings were dry (not oily at removal), the grease pack should suffice. USe a grease that is compatible with the spindle oil that you're using. As in a mineral grease with mineral spindle oil. Not a good idea to mix synthetic with mineral unless you KNOW it is OK
Yes, deep groove ball bearings (DGBB), AS IS, are not good spindle bearings because they are not preloadable and not of the accuracy potential of A/C's. Bridgeport used DGBB"s but they had them specially modified to have them preloaded. A/C's are far superior in accuracy but more costly.
Bridgeport got psuedo A/C performance at almost DGBB price with the special bearing tune ups they did. In the day, this was viable - in today's environment, it is more cost effective to simply install A/C's. More costly but far better performance and accuracy with "bolt in" parts.
IN the long run, you pay more for A/C bearings but don't have to futz with assembling the machine over and over to get it to cut accurately as you do with DGBB"s.
Now, once you install the bearings, where do you plan to have the spindle ID reground??? Unless you do that (grind spindle to run true with new bearing axis), you'll never cut anything smoothly or accurately. Hardinge and Bridgeport ground the spindle ID's whenever they assemble a machine tool spindle. This IS the ONLY way to assure accuracy.
If you want a dead nuts spindle in Z direction, replace the 11770118 screw support bearing on Z axis with a 7014A5TYDUMP4 or P5 grease lubed A/C bearing - mount it in DB. These 7014's will be smoother, more accurate and stiffer than the 9114 Fafnir's that Bridgeport originally used in this position
  #16   Ban this user!
Old 03-15-2007, 04:21 PM
9.5: did you get the machine yet? What can you tell me about the 4th axis?
Is your machine a BMDC based unit? Can you identify who made the 4th axis? OEM system was supposedly Troyke. Is yours an indexer or true servo driven 4th axis???
Any interest in selling the 4th axis, especially if it is plug and play servo system with a BMDC based system?.
We've been looking for a 4th axis and can't find a lot of info on/about the OEM version. Anything you can do to help/share info would be appreciated.
  #17   Ban this user!
Old 03-15-2007, 05:22 PM
9 1/2's Avatar
No I've not yet recieved my machine. Last word was it is now enroute via truck freight.
The 4th axis is a troyke.
  #18   Ban this user!
Old 03-15-2007, 05:23 PM
9 1/2's Avatar
but when i get it. I'll be happy to offer what ever help I can with it, pictures, numbers, general info as you may need.
Sorry I'm not planing on selling it though.
  #19   Ban this user!
Old 03-16-2007, 09:58 AM
I'm looking for a 4th axis for mine and haven't scored or found any yet.
Tried HAAS but they are too much of a PITA to deal with and, besides, the HAAS units don't have the tach needed to interface with the BMDC system even if you could get them to provide one with a DC motor.
Where did you find yours? If its not too personal, what did you pay for the package? I'll probably have to contact Troyke - they said they'd be able to build me one if I sent them a servo motor - I scored a full set of 3 OEM servo's and Motion Science servo amps from a guy who was converting an older FMDC based V2XT system to MACH and steppers.
  #20   Ban this user!
Old 04-18-2007, 10:56 AM
Cool
NC, I'm getting ready to try my 3rd. spindle rebuild for the v2xt. I like the A/C top support bearing idea, thinking about doing it. Do you know of a good bearing seller to go to for them? I got a used spindle shaft off Ebay i'm going to try to use this time. The last guy that ground the taper said there was nothing left to grind on the other one ! Thanks Mike
  #21   Ban this user!
Old 04-18-2007, 12:21 PM
Before you get too far into the process, look up "Bridgeport spindle" or "Bridgeport spindle rebuild" on the 'Zone. If you can find the thread, I explain exactly WHY they used selectively sized bearings on the OEM spindle builds.
If I were doing a spindle tune up, I'd first check the spindle OD size and make sure it is NOMINAL for the particular bearing fit desired. If not, I'd find someone who does jig grinding and grind an oversize OD down or chrome plate oversize and then regrind to size an undersize spindle. This way, you could chuck on the ID to some extent and not have to do a tremendous amount of ID grinding to make the collet register properly.
However, when you get the whole thing reassembled, you WILL want to have the ID touched up by a GOOD spindle shop. At one time, Pope had shops in various places around the country. You might even find a jig grinding shop who could do the work for you.
Don't just drop off the spindle - ask around and go visit some shops. Ask for and then consult references. If you do that, you should be able to get a dynamite rebuild without having to go thru a lot of grief and/or heartache.
As far as bearings shopping, buy quality bearings (SKF, NSK, Barden, Fafnir or the like). Stay away from Ebay or generic bearings. You already know what bargain service can do to the performance of a spindle. Buy the best that you can't afford and you won't be disappointed.
V2XT Programming NC Cams Bridgeport and Hardinge Mills 12 11-01-2008 04:05 AM
Post help hang up? nervis1 Post Processors for MC 6 01-26-2007 03:20 PM
tracking down MDI "hang" with loops & macros howling60 CamSoft Products 7 03-02-2006 02:28 PM
Update V2XT Riverside192 Bridgeport and Hardinge Mills 7 06-30-2005 09:02 AM
V2XT feedback zcases Bridgeport and Hardinge Mills 1 06-13-2005 08:51 PM
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471 472 473 474 475 476 477 478 479 480 481 482 483 484 485 486 487 488 489 490 491 492 493 494 495 496 497 498 499 500 501 502 503 504 505 506 507 508 509 510 511 512 513 514 515 516 517 518 519 520 521 522 523 524 525 526 527 528 529 530 531 532 533 534 535 536 537 538 539 540 541 542 543 544 545 546 547 548 549 550 551 552 553 554 555 556 557 558 559 560 561 562 563 564 565 566 567 568 569 570 571 572 573 574 575 576 577 578 579 580 581 582 583 584 585 586 587 588 589 590 591 592 593 594 595 596 597 598 599 600 601 602 603 604 605 606 607 608 609 610 611 612 613 614 615 616 617 618 619 620 621 622 623 624 625 626 627 628 629 630 631 632 633 634 635 636 637 638 639 640 641 642 643 644 645 646 647 648 649 650 651 652 653 654 655 656 657 658 659 660 661 662 663 664 665 666 667 668 669 670 671 672 673 674 675 676 677 678 679 680 681 682 683 684 685 686 687 688 689 690 691 692 693 694 695 696 697 698 699 700 701 702 703 704 705 706 707 708 709 710
