Old 02-26-2007, 06:51 PM
pestana1957 is on a distinguished road
Bridgeport Series 1 Heidenhain TNC 145
I purchased a used CNC Mill - Bridgeport Series 1 Heidenhain TNC 145 control.
This is my second cnc machine and I do not have much experience of operating CNC machines. The main purpose of this machine is to get hands on experience in milling cnc machining.
I have traid o change the buffer battery and i have lost all the information does any one know how to program it ??
I will appreciate the input of members about their experience and advice and also regarding the various CAM programs I should start exploring.
you can send me the information
to my mail ( mptronica@netmadeira.com )
Pestana1957
Old 02-26-2007, 06:55 PM
gus gus is offline
gus is on a distinguished road
re
is it an interact or a r2c3?
I have a parameter set that will run the r2c3 right out of the box. Probably the interact, but there might be small differences
Old 02-26-2007, 07:03 PM
its an Interact
tanks any help will be good
Old 02-26-2007, 07:10 PM
gus gus is offline
re
I'll get the file together tomorrow when I am in the office
One thing that I know is different is the homing direction in y
If you down load the control tech manuals from heidenhain.com, you will have the parameter definitions
Old 02-27-2007, 10:41 AM
gus gus is offline
re
attached is a parameter list for a bridgeport heidenhain r2c3. parameters 33 and 34 are almost certainly wrong, and all axis travel parameters [31-36] are suspect. THIS WILL TRASH YOUR MACHINE.
Get the manual and find out which is the direction when running over reference marks, as that differs on my r2c3 vs my interact.
Once you can get it homed, you can slowly move it in every direction to see if it stops too early [visual x axis limit] or not soon enough[emo, flashing error]
once you initially enter the parameters, you can edit them by being in metric mode, manual mode, type 95148, enter. delete block gets you out
be careful
Old 02-27-2007, 05:34 PM
Hi Gus first of all tank you for you help,
I have enter the parameters from 0 to 55 and then it gave me an erro
massage (Program Memory Erased)I didn't get to enter the parameters to the end 78, but I have tried and it move´s well the Z axis,the X,Y axis
thoes not move in one direction.tho you have any idea what this be
Tanks
Pestana1957
Old 02-27-2007, 07:59 PM
gus gus is offline
re
Maybe it is an old software rev that only has that many parameters?
the x and y axis issue is the travel limit parameters I told you about
I will try to get my interact parameters tomorrow, that computer died today
Old 02-28-2007, 03:56 AM
gridley51 is on a distinguished road
Pestana,if you give me an email address I will send you the manuals for the 145.
Mark.
Old 02-28-2007, 05:23 AM
Hi Gridldley51
tanks for you help
tanks
Pestana1957
Old 02-28-2007, 04:08 PM
gus gus is offline
re
interact 151 parameters, 2 different sets
parameters 44 to 49 appear to be the relevant axis limit parameters
the rest of the list IS NOT relevant to you machine
BE FREAKIN CAREFUL [BOOM]
Old 03-02-2007, 01:57 PM
Moderator
machintek is on a distinguished road
I found a parameter list from 1983 and I believe it is a TNC145. With descriptions of what each parameter is.
George
  #12   Ban this user!
Old 03-02-2007, 02:20 PM
gus gus is offline
re
appears to be r2c3 rather than interact, so the descriptions would match the first set that I posted
Bridgeport Series 2 Interact 2 Heidenhain TNC 155 rrossey Bridgeport and Hardinge Mills 9 05-16-2011 09:29 AM
Bridgeport Interact 412/Heidenhain TNC 151 HELP? larrynsr Bridgeport and Hardinge Mills 15 08-30-2010 06:06 AM
Bridgeport heidenhain controller????? bherr Bridgeport and Hardinge Mills 4 05-23-2010 02:28 PM
Heidenhain, Bridgeport TNC150 problems! mossy Machine Problems, Solutions , Wireless DNC, serial port 4 10-01-2008 02:08 PM
Looking for help for bridgeport/heidenhain 155 plane magic Bridgeport and Hardinge Mills 6 02-26-2007 08:00 PM
