i finally got my bp2 running and have been trying to program it . today when i powered it up it wouldn,t home. i tried it several times. any ideas???? none of the axis move and shows only manual on the screen along with x y z thanks Dar |
| What happens if you press and hold in the power enable button? Do the drives come up? can the axis move then? This bypasses the limit switches. It may indicate a broken wire or bad swtch in this "string." George
| Do you have compressed air connected? My Interact grumbled without it !
__________________ Andrew Mawson East Sussex, UK |
I had a problem on powerup, I had rapid moved the machine to a limit before shutdown and on start up it wanted me to move the axis to initialise but it wouldn't respond, took a lot of head scratching but the solution is to use the limit bypass switch to move the table off the end stop and all has been well since, learnt not to shut down with machine on limits |
thanks for the advice. today i decided to try it one more time and when i hit the button z went up x ran to the end and then y worked??????? i think my problem aside from knowing very little about cnc machines is this machine is female andits tempermental. |
| Cincinnati Controls | kool-aid13 | General Metal Working Machines | 1 | 05-25-2008 02:08 AM |
| Machine Controls | SPEEDRE | General Electronics Discussion | 2 | 12-14-2006 01:10 PM |
| Building CnC Controls? How? | ZAM | Open Source Controller Boards | 3 | 10-13-2006 02:59 PM |
| Controls | Chuck Pool | General CNC (Mill and Lathe) Control Software (NC) | 7 | 02-23-2006 12:49 PM |
| Controls options | djshop | General CNC (Mill and Lathe) Control Software (NC) | 1 | 01-06-2005 10:59 AM |
